Old 25th July 2010, 10:45 PM   #1
GEirin is offline GEirin  Argentina
Default Compensation in balanced VAS
Hi all.
Problem:
In this circuit, C8 gets the benefit of the Miller Effect because there's voltage swing at the collector of Q5, while C7 does not show the same effect because there was very little voltage swing at the collector of Q4.
Which is the best solution? I have seen different solutions. What is the most effective compensation and best sound?
Old 25th July 2010, 10:46 PM   #2
Different circuits
Kenwood KA89:
- Q13 witch Miller cap C9.
- Q9 cascode transistor, witch collector via R37 to ground. Miller cap C29 in Q9-Q11.
- Phase lead C31.
Old 25th July 2010, 10:47 PM   #3
DenonPOA 2400:
- TR513 witch miller cap C529.
- TR 511 without miller cap.
- TR509 cascode transistor witch capacitor C521 in collector- emisor and collector to ground.
- Phase lead C511.
Old 25th July 2010, 10:48 PM   #4
Mongrel (ostripper)
- Q3 witch miller cap C4
- Q11 cascode transistor witch collector to ground. Miller cap C3 in Q11-Q10.
Old 25th July 2010, 10:49 PM   #5
Supersym (ostripper)
- Q5 witch miller cap C8.
- Q4 witch miller cap C7
- No cascode transistor replace it R48//C6.
Old 25th July 2010, 10:50 PM   #6
Denon PMA 2000
- Q6 witch miller cap
- Q5 without miller cap
- No cascode transistor replace it single R
- R//C Gross compensation.
Old 25th July 2010, 10:52 PM   #7
Any comments are welcome.
Guillermo
Old 26th July 2010, 12:48 AM   #8
Bonsai is offline Bonsai  Taiwan
Well, if the voltage swing between two nodes is limited, as is the case in a number of the circuits above, there is no point in trying to use a miller cap across those two nodes - you acheive nothing.
For the balanced VAS, I've seen a few examples where only one cap is use from the actual VAS output, back to the associated LTP collector.
Another option here is to forget about miller comp and try some other approaches:-
Cordell Audio: Papers: A MOSFET Power Amplifier with Error Correction
bonsai
http://www.hifisonix.com/
Old 26th July 2010, 03:12 AM   #9
ostripper's Avatar
Guillermo
Here is the new one. This works the best for the mongrel. The Kenwood / denons are built around older devices. What compensations are used depends on what is driving it (the VAS) and what it is driving (MOSFETs ,EF2 or TRIPLE OPS).
I have seen 20 other techniques (including Cordells).
All of them work , BUT some sound different , are more stable (VERY device dependant) , and some are just CRAZY , like the shunt comp. on the symasym or the Denon 2000 (they sound the best .. ironically).
OS
Old 26th July 2010, 06:28 AM   #10
ostripper, I think your 5p cap above is going back to the inverting input of the amp, right?
bonsai
A superior VAS clamp and VAS current limit for the Blameless. GK Solid State 128 19th October 2011 03:03 PM
VAS with Miller compensation zero GEirin Solid State 9 28th February 2010 12:36 PM
Cascode VAS miller compensation Rafael L Solid State 9 5th March 2009 01:06 AM
low VAS sealed better than high VAS? matos81 Subwoofers 3 7th April 2006 11:28 AM
Zen Balanced Line Stage Balanced vs Unbalanced macka Pass Labs 28 11th December 2002 06:18 AM
Page generated in 0.10879 seconds (76.40% PHP - 23.60% MySQL) with 11 queries
