Comparing Power BJTs (Sanken, ON Semi, ...)
Old 1st August 2010, 12:37 AM   #11
panson_hk is offline panson_hk  Hong Kong
panson_hk's Avatar
Originally Posted by panson_hk View Post
I measured the Ic/Vce curves of the above BJTs for lower Ic. The DUT has a heatsink (65 x 40 x 20 mm) and cooling fan to avoid over temperature. The setting for curve tracer is written on the white label (mA/div, V/div). Note Ib was 5 mA for MJL21194 whereas Ib was 2 mA for other BJTs. What can see all BJTs have Ic nearly independent to Vce (ideal transistor Ic/Vce curves) when Ic is less than 2.5 A and Vce = 5 V. These are the Ic and Vce levels for a two-pair output stage driving a load consisting of 2 uF // 6 Ohm as shown in the simulation mode below where supply rails is +/- 40 V. The BJTs are nearly "ideal".
From the curves, we can see that the clipping levels (Ic = 2.5 A) for 2SC and NJL are about 10 volts from supply rails. On the other hand, 21193/93 is about 5 V.
Old 1st August 2010, 09:33 AM   #12
jan.didden is online now jan.didden  Europe
jan.didden's Avatar
Douglas Self has also written about this and he coined the term 'load-invariant power amp' IIRC. Basically he looked at the increased linearity with more output pairs.
One way to look at that is that if you double the output pair, it LOOKS for each pair as if the load has doubled from say 8 ohms to 16 ohms as the required Ic for one pair for a certain output level is halved.
If you also want to keep the advantage of lower Vce you would tend to speakers with low impedance (like 4 ohms drivers) for low output signal for a certain sound level, coupled with multiple output pairs.
jd
Advertising is the rattling of a stick inside a swill bucket - George Orwell
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
Old 1st August 2010, 12:05 PM   #13
wahab is offline wahab  Algeria
Right.
That s why i use at least two power devices pairs for a 50W/8R amp.
The only drawback is power dissipation at iddle, but since most designs
are AB class, it doesn t really matter.
Old 28th November 2012, 01:29 PM   #14
catalin is offline catalin  Romania
Great work Panson !
Congrat's !
"please try to listen to some music through the amplifier instead. Life is so short ..."
Old 28th November 2012, 10:48 PM   #15
Telstar is offline Telstar  Italy
I missed this thread. Good work!
It confirms why i prefer the NJL devices.
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 29th November 2012, 02:24 AM   #16
panson_hk's Avatar
Thank you guys! NJL is also my first choice.
Comparing Power BJTs (Sanken, ON Semi, ...)Hide this!Advertise here!
High linearty low-power BJTs and Class A headphone amp percy Headphone Systems 24 27th July 2009 06:00 PM
Looking for SPICE models of power BJTs Jorge Solid State 9 21st July 2005 02:13 PM
Toshiba JFETs BJTs Sanken BJTs Praise! Swap Meet 5 14th February 2004 07:45 AM
Toshiba power BJTs now at digikey mirlo Parts 8 28th February 2003 08:46 PM
