2sk1058 mosfet amp - Page 2 - diyAudio
Old 27th July 2010, 01:54 PM   #11
lineup is offline lineup  Sweden
lineup's Avatar
I ran this amplifier in SPICE.
It is not what we can call HIFI. It is more a great project for fun
The harmonic distortion was several %. Up to like THD 5%
About the maximum Output Watt.
We have only 0.8 Ampere across 15 Ohm resistor.
The load is 15 Ohm in Parallell with 8 Ohm ... gives like 5.2 Ohm
0.8A x 5.2 = 4.17 Vpeak, as mentioned by ilimzn
Output is 2.95 Vrms which makes 1.08 Watt max output, teoretically
To increase output Watt a little bit
I would make the power resistor 10 Ohm, instead of 15
This gives a current of 1.2 Ampere (12V / 10 Ohm)
lineup
Old 27th July 2010, 03:42 PM   #12
ilimzn is offline ilimzn  Croatia
You can also optimize the DC at the output and get a bit more, perhaps 2W out, and this will also decrease distortion at low levels because of the increase in idle current, but it will increase the rise of distortion with power because of decreasing Vds of the MOSFET (nonlinear input capacitance... the effect will be less if the source is low impedance).
Old 27th July 2010, 11:17 PM   #13
tubem is offline tubem  Canada
The original authors comments on this project can be seen at this site.DIY AUDIO PROJECTS - Do-It-Yourself Hi-Fi for Audiophiles My actual test results of this amp will be posted when they are complete. I will say though , it really does boot out big sound for what it is.
Old 28th July 2010, 02:19 AM   #14
Junm is offline Junm  Philippines
Junm's Avatar
Send a message via Yahoo to Junm
Hi ILIMZN.....
If I use an 8 ohm load resistor and 8 ohms load speaker and set Vq to 10v will the output power be increased to what value? current is increased 1.75A.
will it be better?
Old 28th July 2010, 03:11 AM   #15
This can, too interest in the
Old 28th July 2010, 10:56 AM   #16
much of what is being discussed here is also in the PASS website.
Single ended resistor loaded ClassA amplifiers is where it all starts.
Then one adds CCS loading and moves on to Push Pull. It is all in PASS.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 28th July 2010, 01:40 PM   #17
Banned
Congratulations.
If you are hooked already like the rest of us here build the F5 for your next amp.
Old 28th July 2010, 01:47 PM   #18
Banned
This might be interesting, it wouldn't take too long to try it out.
Old 28th July 2010, 05:00 PM   #19
There is so much MAGIC in the single ended zero feedback sound that it is easy to ignore its deficiencies . I would like to see and hear of more projects and experiences in this pursuit . I am a big fan of single ended tube amps . Thank you for sharing your hollow state adventure tubem !!!
Old 28th July 2010, 05:45 PM   #20
Banned
Referring to your amp, the easiest mod you could try would be replacing the 15Ohm resistor with a constant current source, once you have tried that, replace the constant current source with an Aleph current source.
Lateral MOSFET replacements for 2SK1058 (Hitachi) jgwinner Solid State 26 12th June 2014 07:33 PM
Renesas Hitachi 2SK1058 & 2SJ162 Lateral MOSFET billanichols Solid State 6 30th November 2011 09:18 PM
2sk1058 mosfet amp tubem Introductions 1 20th July 2010 02:46 AM
Any class A amp with 2SK1058/2SJ162 ?? nina Solid State 16 26th February 2008 11:38 AM
Copyright 1999-2017 diyAudio
