I just bough that GFA 5500 as it looked great on paper. 200wpc, 700 damping factor, Mosfets. I expected that huge brick to sound like my Hafler 500, with some extra bass control as a bonus. Am I the only one to think it sounds harsh, very harsh? I am quite disapointed... The upper mids and highs are grainy and boosted. It was obvious right off the bat.
My choices are simple. Keep it to power subs, or find an easy fix. Can anything be done that doesn't involve shipping it to Musical Concept? Perhaps some filtering/smoothing on the output caps |
#2 |
Do you have the schematic?
I thought the GFA5500 was a BJT design, and that the GFA5800 was FET.
Candidates for the Darwin Award should not read this author. |
#3 |
I have only been able to find the owner manual by now. Still searching for some schematic ;-)
#4 |
#5 |
i wonder if your 5500 uses an inductor together with a zobel in the output ... i also wonder what type and how long cables you use ....
someone has to come up with a schmatic so we can verify that ...
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#6 |
Back on the subject.
Two things I immediately noted when firing up the amp was the over abundance of upper mids and low highs, and "that" grain. A few days later, I can say that the grain has disapeared. And it is not that I got used to it as I have been swapping amps. Most likely the grain was temporary and caused by the Cambridge D500 CD player which sometimes "fails" on power on. What remains is that over-generous and agressive upper mids. I guess that I can filter them out by fitting smoothing caps on the four big capacitors. Or maybe I only used to the Hafler and Quad sound texture... ;-) |
#7 |
back on the subject means exactly what ? do you belive that one of the above posts or replies is out of subject ? at least this is the way i understand it ...
#8 |
No, no. no. Everyone has been helpfull and I thank you all for your help. I only meant that I was out for a few days and didn't want posters to think I quit on them ;-) I am still searching for a schematic as the amp has potential and only needs a little tweak. Who would say no to an amp with a 700 damping factor? And it is quiet, which can't be daid of my Hafler 500 which sounds great but runs on a fan.
The reviews on the net show a larger percentage of owners who find the sound smooth, while others find it agressive and somewhat harsh. So, I don't know what to think. I have been using different types of interconnects and cables. Same proeminent upper frequencies. |
#9 |
that is ok then .... lift the cover and let me know if there is an inductor ..please
#10 |
| sheng ya cd o2 harshness | duderduderini | Digital Source | 2 | 17th May 2006 02:46 PM |
| FS:Adcom GFA 555 and GFA 5300 | trusound | Swap Meet | 0 | 13th December 2005 05:06 PM |
| Changing the filter to remove harshness | Ralph | Multi-Way | 36 | 15th October 2005 08:33 PM |
| Fixing Loudspeaker | kambule | Multi-Way | 2 | 10th June 2005 11:44 AM |
| What causes increasing harshness as the volume goes up? | Saurav | Everything Else | 9 | 17th December 2003 09:21 PM |
| Page generated in 0.09499 seconds (79.63% PHP - 20.37% MySQL) with 11 queries |
