Hello SolidState Man
in this project you can see all the best of my Science this buffer with cascode have as load two SRPP this circuit can works with estreme audio accuracy
visit my best audio idea http://www.esafono.it/DACTONE.htm |
#2 |
#3 |
the target is have a Centre with Compact Disc like Vinil
![]() the way is a complete compensation of each device
#4 |
symmetric CCS feed , cascoded complementary jfet buffer , feeding MF A1
what's new there ?
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#5 |
Why is there a current source on the collector of the cascode transistor? This would equate to two current sources in series
Simpler yet would be to use larger goss J-fets as the cascode transistors (larger Vgs) and completely forget the voltage divider and current sources. AKA Erno Borbely
All the trouble I've ever been in started out as fun...... Last edited by CBS240; 17th July 2010 at 07:42 PM. |
#6 |
R.I.P.
I suspect it won't actually work, and is a theoretical idea never tested.
Why? The purpose of a buffer is to drive lower impedances than the basic previous signal circuit can drive - yes? But above each cascoded fet source follower is an EXTREMELY tight CCS, so where can peak currents come from that will be needed into any lowish impedance load? Stee? Regards, Allen |
| Power J-fet + PNP buffer | Nrik | Solid State | 9 | 16th May 2010 09:31 PM |
| J Fet Buffer problem - help ! | AndrewGM | Solid State | 6 | 22nd October 2009 10:14 PM |
| All fet super buffer | Pasul | Solid State | 4 | 7th December 2008 05:25 AM |
| Fet buffer (?) for I/V stage ? | Bernhard | Digital Source | 44 | 17th November 2004 09:38 AM |
| Page generated in 0.08316 seconds (76.38% PHP - 23.62% MySQL) with 11 queries |
