hi,
i'm in the midst of doing up my first solid state amp \ building nelson pass's delite now, and if i have a centre tap transformer that gives me rectified +75 and -75V, i've grounded the centre tap would i need to connect the output coupling capacitor in reverse for the -75V channel? or would the delite amp require a transformer with 2 separate windings of 0-75 rectified??? |
#2 |
You should ask in Pass Labs forum.
Maybe even he will answer himself!
lineup |
#3 | |
jd
/Another new issue: Linear Audio Volume 3! Last edited by janneman; 17th July 2010 at 08:21 AM. Reason: removed nonsense |
#4 | |
is there any use for the -75 line then? so essentially i'm using only half the transformer? |
#5 | |
If you feed two amps from the 75V you use as much transformer capacity as when you would feed one amp from the +75 and another amp from the -75. Except that feeding one amp from a -75 would require rearranging the amp ground, and that's unnecessary. jd
/Another new issue: Linear Audio Volume 3! |
| Dumb question on Coupling cap ratings... | john65b | Tubes / Valves | 9 | 18th October 2008 01:26 PM |
| Do I always need an output coupling cap? | Dominique | Solid State | 11 | 25th February 2005 09:35 AM |
| A dumb question about coupling caps. | G | Tubes / Valves | 32 | 29th August 2003 07:26 PM |
| dumb power supply question | nobody special | Pass Labs | 2 | 12th January 2003 10:12 PM |
| Page generated in 0.07927 seconds (74.96% PHP - 25.04% MySQL) with 10 queries |
