The voltage regulators in my Delta 1010's power supply are getting very hot because they are being fed an input voltage that's too high. The +/-15V regs are getting an input of about 25.5V and the +5V regs are getting an input of about 13V. I would like to reduce the input voltages by putting a resistor just before the input of the regs. Below is a schematic of the PSU with the additional resistors drawn in red. There's just one thing I'm not sure of. If you notice, there's a difference in the placement of the resistor for the input of U4 (+15V reg) versus the resistor for the input of U6 (+5V reg). The resistor for U4 looks like it's in parallel with the decoupling cap C15, whereas the resistor for U6 looks like it's in series with the decoupling cap C24. Which one of these is the proper or better placement, or does it matter -- will they work equally well?
Any help would be really appreciated. Thanks in advance! |
#2 |
It depends on the circuit that is being powered on what I would do.
Adding resistors might reduce the heat but will it then cause the regulators to drop out ? A simple answer might be too put larger heatsinks on the regulators. When you say the regulators get hot, how hot ? They can go over 100 degrees C and still be OK. Silicon can go upto 150 degrees C before it dies although I wouldnt suggest going close to that.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#3 | |
Isn't the optimum input voltage for regulators the output voltage plus 3 volts, and any input voltage in excess of that is dissipated as heat? I would like to bring down the input voltage of the +/-15V regs from 25.5V to 18V, and the input voltage of the +5V regs from 13V to 8V. I have already put additional large heat sinks on the +/-15V regs. Even with that they are still hot. The -15V reg is getting the hottest with a temp of 72.5C. The +15V reg is 60.2C. Both temps were measured by placing the temp probe on the heat sink for 40 secs. I also wonder why the -15V reg temp is a lot (12C) higher than the +15V reg. Do you think that, in addition to putting the resistors, replacing the regulators with low drop-out type will also help? Last edited by mtl777; 16th July 2010 at 09:45 PM. |
#4 |
The 3 volts across a regulator is the drop out voltage.
Any less than 3 volts and you wont get the right voltage out. You need some headroom for when more or less power is being used by the system.
#5 |
But the input voltages are really too high, aren't they? I think the regs need only 18V and 8V to function properly. 25.5V and 13V are way too much.
Back to my original question, without considering other things but just looking at the question from a proper circuit design standpoint, which one of those resistor positions is the proper or better placement, or does it matter -- will they work equally well? Thanks! |
#6 |
A LM7815 is rated to 125deg C . 60 to 70 deg should be OK.
I recently had a problem with a 15V reguator overheating, it had melted the solder and lifted the tracks off the PCB! Adding a bigger heatsink stopped it from going into thermal shutdown ![]() Due to the nature of this power supply being a voltage doubler for the 15 - 0 - 15 supplies it has very poor regulation. A voltage reduction from 9V AC to 7.5V AC would cause a dropout. I would say that the high voltage reduction across the regulators ensures correct operation of the PSU in all conditions. |
#7 | |
One side effect of the heat is that the smoothing caps are affected and are deteriorating fast. I put in new smoothing caps last week and got very clean THD+Noise graphs in RMAA. But after subjecting the unit to 14 hours burn-in, the graphs suddenly started to look bad. Now they are getting badder and badder each day that I turn on the unit and test with RMAA. I really need to reduce the temps! |
#8 |
You want the decoupling capacitor after the resistor to stabilize the voltage regulator.
U6 circuit. |
#9 |
#10 |
I have another question: Would it help the circuit to produce cleaner power if I replace the regulators with low drop-out types like LM2940 and LM2990? What are low drop-out regulators used for? In what situations are they preferable to use? What are their advantages and disadvantages versus non-LDO?
Thanks again! |
| Delta 1010 Mods: op-Amps, Caps, power supply, clock | hendrikxix | Digital Source | 2 | 31st May 2008 04:48 PM |
| Delta 1010 Clock Mod | mtl777 | Digital Source | 76 | 20th May 2008 09:12 PM |
| Delta 1010 output noise | Wavne | Digital Source | 1 | 12th October 2007 08:30 PM |
| Delta 1010 Recapping Mods | mtl777 | Digital Source | 7 | 11th October 2007 12:13 AM |
| Word Clock For M-Audio Delta 1010 | 300_baud | Digital Source | 0 | 19th August 2006 05:08 PM |
| Page generated in 0.15762 seconds (64.56% PHP - 35.44% MySQL) with 11 queries |
