Old 16th July 2010, 05:08 AM   #1
Default Manufacturer of Low Noise JFETs
Is anyone familiar with Moxtek? They advertise really low noise jfets (En <0.5 nV/sqrt(Hz) in either TO72 packages or loose dies. They have a website describing their devices, and their intended application is very different from audio: the front end amps for SiLi and GeLi x-ray spectrometers. They make only n-channel devices, and I bet they are not cheap.
http://www.moxtek.com/PDF/JFETs/DAT-MX%20JFETS.pdf
JCM
Old 16th July 2010, 05:31 AM   #2
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Intriguing. I wonder what the 'reset' and 'feedback' pins do?
jd
/Another new issue: Linear Audio Volume 3!
Old 16th July 2010, 01:35 PM   #3
En < 0.5 nV/sqrt(Hz)
I don't see any part meeting this spec; MX-16 is 0.6 nV/sqrt(Hz) typ. at 10 kHz and -100° C. It seems they have low capacitance though (which is important for charge amplifiers as far as I know).
Samuel
Old 16th July 2010, 01:40 PM   #4
I'd say just brought out additional gate connections for low stray capacitance. Charge amplifiers have capacitive feedback (with very low feedback capacitances possibly below the pF range), and the reset pin is used to inject a pulsed charge to zero the amplifier output in order to prevent it from saturation.
Samuel
Old 16th July 2010, 02:05 PM   #5
juma is online now juma  Serbia
juma's Avatar
Cheap and common BF862:
0.8 nV/sqrt(Hz) at 100kHz and 25° C.
http://www.nxp.com/documents/data_sheet/BF862.pdf
Low noise transistor and noise figure Real_Macgyver Solid State 26 31st January 2011 01:34 PM
anyone tried this for low noise 5v? mlloyd1 Digital Source 1 25th May 2006 12:06 PM
Noise figure vs signal source resistances in JFETS datasheet rlim Solid State 25 19th December 2003 07:11 PM
Best low-noise low-distortion buffer? borges Solid State 7 9th December 2003 12:40 PM
mosfets or JFETS with low Ciss RichardJones Pass Labs 10 5th August 2002 10:38 PM
Page generated in 0.10024 seconds (78.26% PHP - 21.74% MySQL) with 10 queries
