Yes - thank you very much. How you have discover this portal?
Except the "SA 20-20" I have now all schematics here asked. Thus I will ask David Glass about this first solid state amp model from Crown.There is some early stuff not on their website. Email David Glass (DGlass@crownintl.com) if you can't find it. Also ask for any subsequent tech notes for the equipment you're working on. Often the tech notes will address the problem you're having. Normally you have to be a service center to get to the tech notes online.
Note: David is not a heavy duty technical guy but is more of a customer service engineer.
Thank you for his email address.
if you want and it's not so complicated for you, you can try to find out more informations of world's first solid state amplifier - Cervin Vega's ER-123 - go to post #10 about.....you're welcome, no problems. Once I was searching a topic in the net and the links drove me to this portal.
http://www.diyaudio.com/forums/soli...id-state-audio-amplifier-components-want.html
and post #1 about
http://www.diyaudio.com/forums/solid-state/171619-first-solid-state-amp-cerwin-vega-not.html
I haven't this amp for repair service and thus this it's not really urgent.
So you can do this if you really have time - thank you.
How important is it that the input capacitor C201 in this schematic is a non-polar type? If it has to be one of those, can someone recommend a high quality brand that I could use? I can only find ordinary Panasonic one:
Digi-Key - P1281-ND (Manufacturer - ECE-A1HN220U)
