i have a technics integrated amp that turns on but no speaker relay click . i opend the case an d found the resisitor 616 burnt beyond recognition. i have downloade the service manual from 2 diferent sites but the resistor value its not clear. can somebody give me the correct value of this resistor, thanks.
#2 |
SU-V2? Those used STK 80xx modules right?
If so, your likely fault is one of those modules...they like to fail short circuit and put a voltage rail on the output! The protection circuit sees this and opens the relay to save your speakers. Check for DC voltage with respect to ground on the speaker relay input leads. One relay handles both channels if I recall correctly. Thus is one channel faults, both channels are disconnected from the speakers. Unless the resistor in question is in the protection circuit, look for one in the same position circuitry wise on the other channel. Its a symmetrical circuit. SU-V4 is similar but more powerful. SU-V4 used STK-8050. (SU-V3 and V5 are different entirely...complementary discreet transistors!) Last edited by hardwareguy; 13th July 2010 at 06:37 AM. |
#3 |
i have the schematic but it seems that i am anible to locate R616 it seems that doesnt exist the schematic i have is SU V2X is that correct ???
let me know
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#4 |
SU-V2 and SU-V2X are different amplifiers. Judging by the appearance of the old SU-V7 and the SU-V7X (which I own and love!) the internal differences are likely to be massive.
What power amp IC does the V2X use? I'm curious. |
#5 |
ok seen the diference my shelf ....correct these are two diferent amplifiers ...i have the schematic of the suv2 also ....
the resisttor in question R616 is the same with 615 and its 390R expect capacitor 605-606 to be faulty and tranistors 601-602 may be ... outputs shorted or faulty is also a chance ...verify ofset before everything else ....if you need schematic ...e mail me regards sakis
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr Last edited by sakis; 13th July 2010 at 07:04 AM. |
#6 |
The SU-V2 has discreet transistors? Or is it STK?
Just curious...got a schematic for SU-V5? Ive got one and its not happy. |
#7 |
yeap ....suv 5 is also available please e mail me if you like to have it ... kind regards sakis
#8 |
R616 is 5% carbon resistor, 390R/0,25W the same as R615.
Non é mai abbastanza... |
#9 |
thanks for the help, the resistor in question is in the main main part of the amp and is near the speaker outputs,i did what hardwareguy said and found out is the same as 615 390R/0,25w 5% like aparatusonitus said also. is this resistor could triger the protection circuit to act?(stedy red light in the power buton) i will replace resistor for same and will post results. thanks again. here some pics of the board and position of the resistor.
#10 |
SU V2 uses stk 8040 transistors
| 80s Amps: Technics New Class A, SU-V2X | arki | Chip Amps | 6 | 7th December 2010 11:57 AM |
| Problem with Technics RS-616 | Hentai | Analogue Source | 1 | 10th September 2008 09:01 AM |
| Power Amp of Technics SU-V90D | Loavn | Solid State | 12 | 7th March 2008 09:29 AM |
| Technics SU-600 Amp | kahukong | Solid State | 0 | 12th January 2005 01:47 AM |
| Need schem for a Technics RS-616 Cassette Deck | mig-ru | Analogue Source | 3 | 4th July 2003 10:39 AM |
| Page generated in 0.10041 seconds (81.63% PHP - 18.37% MySQL) with 11 queries |
