hi is there any drawbacks to connecting heatsinks in series to make a large one for output transistors?
regards chris |
#3 |
could you mean parallel?
If there are alternative routes for heatflow then I call that parallel. If all the heatflow must pass, in sequence, through all the heatsinks then I define that as in series.
regards Andrew T. |
#4 |
using separated hetasinks for N transistors and seperated for P is guarantee of thermal run away
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#5 |
Enjoy good sound
Why? As long as there is no severe DC offset the same current pass N and P transistors. Cooling symmetry (P N) will be required though.
/ Anders |
#6 |
wrong even audio signal it shelf migh include pos or neg peaks of diferent magnitute that might drive the p or the n side of the amp warmer than the other ....now if the vbe multiplier is attached on the other side will not sense that and if the amp is pushed then kabooooooom
#7 |
Enjoy good sound
Under such circumstances I agree of course.
/ Anders |
#8 |
#9 |
Enjoy good sound
Did I write otherwise?
/ Anders |
#10 |
yes sorry i should have been more clear, yes they would be connected edge to edge, and the pcb and output trannys would sandwich a piece of aluminium angle which would in turn run the length of both heatsinks.
| Wanted - 2-4 Heatsinks suitable for Pass F Series Amp | Tripmaster | Swap Meet | 4 | 31st March 2010 07:17 PM |
| Intel CPU heatsinks as power output transistor heatsinks? | deltavektor | Solid State | 4 | 29th November 2009 01:47 PM |
| Connecting OSCONs in series for high voltage. | Fanuc | Solid State | 6 | 22nd March 2007 11:51 PM |
| Series connecting output Transformers. | Shoog | Tubes / Valves | 55 | 12th February 2007 05:22 PM |
| connecting heatsinks | meta | Parts | 1 | 15th July 2003 07:28 AM |
| Page generated in 0.09571 seconds (76.74% PHP - 23.26% MySQL) with 10 queries |
