Old 27th June 2003, 01:23 AM   #1
jackinnj's Avatar
Default Why not "instrumentation amplifiers"
ok, I was reading one of the ADI ap-notes on instrumentation amplifiers, I realize that they aren't any good as integrators and differentiators, are somewhat expensive -- but why aren't people using them as gain blocks in audio applications? Is it just the expense, is it the necessity of nulling offset, <em> dit a mois pour
Old 27th June 2003, 04:38 AM   #2
Banned
Default Maybe you don't use them.......
I know people who do.....especially for balanced inputs.
Jocko
Old 27th June 2003, 06:02 AM   #3
... because most people don't listen
to instrumental music ? .......
Old 27th June 2003, 06:26 AM   #4
stokessd's Avatar
Lots of people DO use them. I have a phono stage design which uses BB INA103's in the front end.
They can be quite good, amazingly good, but as you stated, they aren't as universal as an op-amp.
Sheldon
Old 27th June 2003, 06:42 AM   #5
Account Disabled
Default Re: Why not &quot;instrumentation amplifiers&quot;
Originally posted by jackinnj
ok, I was reading one of the ADI ap-notes on instrumentation amplifiers, I realize that they aren't any good as integrators and differentiators, are somewhat expensive -- but why aren't people using them as gain blocks in audio applications? Is it just the expense, is it the necessity of nulling offset, &lt;em&gt; dit a mois pour
...see:
http://www.jensen-transformers.com/an/ingenaes.pdf
Old 27th June 2003, 06:59 AM   #6
[QUOTE]Originally posted by stokessd
[B]Lots of people DO use them. I have a phono stage design which uses BB INA103's in the front end.
I have one of these in a Carver Active/Passive Preamp. The balanced output is passive; the single ended has gain and contains the IN103. In comparison with the passive mode, the single ended mode doen't sound very good at all - you wouldn't use it unless you MUST.
Old 28th June 2003, 08:07 AM   #7
Default they work...
yes,I built the design found in 'audio amateur' 6/95 ; 'An instrumentation preamp' and over the yrs. substituted various op-amps for the originally speced tl-072's. I am quite impressed with this simple design and still use it today-
Old 28th June 2003, 09:10 AM   #8
Account Disabled
Default Re: they work...
Do you have the schematic...can you post it?
Old 28th June 2003, 01:07 PM   #9
jackinnj's Avatar
Are you sure the design wasn't in 2/95 "An Instrumentation Preamp" ?
While there are now better power supply designs, the author did add a soft start feature which prevented turn-on thump, and a soft-finish feature which powered off the preamp first, then the power supply. The pre-amp used multiple TL-072's in an "instrumentation" configuration, but not an off-the-shelf instrumentation operational amplifier.
I have some ADI and TI (Burr-Brown) Instrumentation ampls to play with. I guess the thing to do is compare to the TL-072's.
Jack
Old 28th June 2003, 01:27 PM   #10
jackinnj's Avatar
Here's a link to the Analog Devices article on Instrumentation Amplifiers: http://www.analog.com/UploadedFiles/...06604AN244.pdf
Anyone have Jan 1987 Stereo Review "Do All Amplifiers.." cuibono Everything Else 13 16th March 2012 08:37 AM
Book "Evolve Power Amplifiers" from Shinichi-Kamijo in English ? tiefbassuebertr Solid State 2 13th August 2009 04:22 AM
Difference betweeen Class D and "Digital Amplifiers" percy Class D 105 13th March 2007 02:03 AM
Morgan Jones "Valve Amplifiers" gingertube Tubes / Valves 21 15th March 2005 01:16 PM
Book for FS "Build your own Audio Valve Amplifiers by Rainer Zur Linde (English)" zobsky Swap Meet 0 5th April 2002 05:18 PM
Copyright ©1999-2013 diyAudio
