Repairing a short wave receiver I have run into a problem with the audio.
A little background.... The receiver is a SONY SW77 and uses a NEC C1316 power amp. It is capable of stereo in this application. The task at hand was to replace leaky and possible shorted SMD electrolytic capacitors, a job I have done many times with good success. One repair with the same audio IC, a bad cap had shorted the audio chip and in turn took out a B+ transistor, A SOT device. Replacing both, the radio was a success. I am thinking the same is here but the damage is slightly less but enough to cause a dysfunction. On the SW77 the audio is not bad at a higher setting but as it is lowered. the tone slightly changes and the volume never goes to zero. BTW the volume control is a slide potentiometer. Discrete parts are getting hard to find! What do the Gurus think? Thanks in advance! Rod KB8DNS |
#2 |
ground is missing from some point
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#3 |
σας ευχαριστώ Sakis!
Makes perfect sense and it could be in the IC amp it self! I will dig deeper into this and look with a magnifier. Atios! 73 Rod KB8DNS |
#4 |
This is a bit late but I found the problem in a most curious way.... As I was examining the circuit board as it was in the cabinet, I spotted a small tan rectangle shaped object stuck to the speaker magnet....
Turned out to be a SMD capacitor and then the Aha! moment.... A search of the circuit board and I found the spot where it belonged, re-soldering it and the sealing it down the stereo was fully restored! ![]() Goes to show one must keep your eyes open! I am not sure of what happened but it may go back to when the radio was new as someone had tried to boost the signal to the CX chip for AM / FM by soldering a wire directly from the antenna terminal. Back it went to the owner in Belgium! Rod KB8DNS |
| tda8560 audio amp wiring problem | Adumas | Chip Amps | 7 | 17th March 2010 09:21 AM |
| Book FS: Audio IC Op-Amp Applications by Jung | davidhs | Swap Meet | 2 | 15th July 2007 03:21 PM |
| Kole Audio Amp Problem...HELP | dozan1 | Car Audio | 4 | 14th February 2007 06:51 AM |
| Problem with IC 555 | Gunawan W | Parts | 2 | 15th October 2004 04:57 AM |
| Page generated in 0.08704 seconds (72.56% PHP - 27.44% MySQL) with 10 queries |
