Option to High Voltage Medium (Video) and High Power Devices for Output and VAS Stage Option to High Voltage Medium (Video) and High Power Devices for Output and VAS Stage - diyAudio
Old 9th July 2010, 07:38 PM   #1
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
Default Option to High Voltage Medium (Video) and High Power Devices for Output and VAS Stage
Motorola's new approach arround 1977 - serial cascaded power devices instead very special BjT's with High Voltage UCE
In the German magazine "Funkschau" issue 4/1977, page 61/161 I read the article
"Reihengekoppelte Ausgangsstufe ermöglicht hohe Leistung bei niederigen Kosten" Translate:
Cascaded Power Follower allows High Power and Low Cost at the same Time
A serious option to (often hard to find) high voltage power devices (and also VAS medium power) transistors with not very favorable parameters.
Here my translation from German language:
In opposite to a normal cascode - i. e. fix voltage for the lower transistor - it is to see instead the typical zener also a resistor (see attachement). But similar to the normal cascode, the lower transistor is to be drive while the upper works as a slave. Because the bias voltage (0,5 UCC) corresponds to half the supply voltage UCC , UCE from upper and lower transistor always has the same value. This concept was developed in Motorola's European consumer laboratory
For this approach Motorola has developed a very special series of power devices with very high hfe (>20 at 10A).
There are three Uce groups:
1) 50V: BD364/365
2) 60V: BD366/367
3) 80V: BD368/369
The number of cascaded series devices is of course not limited to two pcs.
The original application paper from Motorola wanted.
Old 26th August 2012, 07:15 AM   #3
Most of the useful VAS transistors from my line up about
http://www.diyaudio.com/forums/solid...-overview.html
are obsolete, particularly the SANYO ones. Therefore I still looking for the mentioned Motorola application note from post #1.
Option to High Voltage Medium (Video) and High Power Devices for Output and VAS StageHide this!Advertise here!
Which high power CCS for output stage? andyjevans Tubes / Valves 25 4th May 2017 05:28 AM
High power ALEPH J (6 output devices); any attempts yet? elac310 Pass Labs 11 17th May 2009 05:33 PM
Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. kimbal Tubes / Valves 4 11th May 2009 08:05 PM
Very High Voltage Amp Output Stage rtarbell Solid State 12 16th May 2006 05:49 PM
High voltage transistors for VAS stage rtarbell Parts 4 15th November 2005 12:13 AM
Copyright ©1999-2017 diyAudio
