Old 6th July 2010, 10:17 AM   #1
diyAudio Moderator Emeritus
Default Marantz PM8003 service manual
Where can I get service manual for Marantz PM8003?
Old 6th July 2010, 10:22 AM   #2
sakis is offline sakis  Greece
sakis's Avatar
i have 8000 if this is any help to you .... but also know my ways arround those is there a chance that i can give you my help ????
( some times ago i solved a weird problem on those with succes )
kind regards sakis
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 6th July 2010, 01:40 PM   #3
Thanks, but I've already got that one. Seems different at first sight.
Old 6th July 2010, 01:56 PM   #4
sakis's Avatar
state the type of your problem if you like
Old 7th July 2010, 02:15 AM   #5
A friend of mine brings me his PM8003. The sound is somehow "not involving". Something is missing. I want to look at the the circuit first. Maybe the bandiwth of the filters or something else can be changed.
Old 7th July 2010, 07:04 AM   #6
sakis's Avatar
ok ...got the picture ...
what i would do ...
---- first listen and take scope readings from the machine as is
---- then a good spot to actually isolate everything from everything is the volume pot pcb
***there you have the signal from selector switch
*** from there its rerooted to the tone control
*** and exactly behind the tone control is a pcb that features volume buffer and auxiliary psu ... ( from there we go to the main amplifier ) ( nice place to look at )
faults i found in several of these amps
---thermal stress arround LTP courent source area /main amplifier /poor soldering
---genarally soldering isues in the main amplifier area
--- tone contols pots and source direct switch get dirty very easy
--- main procesor reset ic fails easily
--- selector area eventhough relay operated has terrible cross talk
this is it more or less ...kind regards sakis
marantz sc 7 service manual Orgonom Solid State 1 4th November 2009 01:43 PM
Marantz CD7300 Service Manual gbyleveldt Digital Source 0 16th July 2008 11:30 AM
Looking for Marantz CD65II service manual electropt Digital Source 9 24th March 2007 09:56 AM
Marantz CD63 Service Manual johnmarkp Digital Source 8 19th May 2006 09:33 PM
Marantz CD95 service manual jchou Digital Source 0 15th October 2004 07:26 AM
Page generated in 0.08423 seconds (73.29% PHP - 26.71% MySQL) with 10 queries
