Bias in a classical current feedback amp - influence how?
Old 18th November 2003, 12:04 PM   #81
PMA is offline PMA  Europe
PMA's Avatar
Originally posted by peranders
Yes, I think SMD for DIY'ers is the next thing and also current feedback.....
Next step is to use 0204 parts
.... or TAS5111 ...
Old 18th November 2003, 02:30 PM   #82
bocka is offline bocka  Germany
Well, I'm only using µBGA if they're available. Prevents my projects to be copied...
0603 could be used by some DIYers, not small enough and can be soldered when using a fine tip.
Old 19th November 2003, 04:20 AM   #83
sonnya is offline sonnya  Denmark
sonnya's Avatar
I have done some simulating on a SMD current feedback amp with Diamond buffer and the performance seems to be rather good. Bandwidth up to 25 MHz but how about real world influence? I expect over 1 MHz is very possible, maybe 10 MHz.
I notice that working point aren't very sensitive. 0.5 mA or 5 mA doesn´t mean much.
I'm very keen on making a small cute all SMD headphone amp, mayby with Jung Super Regulators.
I have attached the simulation files if somebody wants to fool around.
Bandwidth up to 1MHz is very possible, also in a poweramplifier. Just use Emitterfollower as output. Maybe use MOSFET's.
Try out other combinations of currentmirrors. As i have found out you can gain more phase margin than with the current mirrors you have used right know.
I my self would like high idle current, so it isn't jumping between class B and A when slewing fast.
Mirand Audio amps and Dac's - http://mirand-audio.dk/?post_type=product
Old 19th November 2003, 07:05 AM   #84
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
If I choose to have 10pF I get 70 deg, 22pF, 64 deg, 47pF, 55 deg.
22pF = 14 MHz, 47pF = 6 MHz
Simulationwise I think Wilson mirrors aren't so bad.
I have adjusted the currents somewhat but I have kept them rather low so my poor pcb won't go into flames. Total power consumption for one channel is 0.8 Watt.
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 20th November 2003, 08:10 AM   #85
peranders's Avatar
Here is the schematics which I'm working on. At the moment I have only one channel. First I'll make the pcb layout for one channel ready then I will duplicated it.
I wonder how good the temp stability will be? May I'll have to reduce the currents? I'll guess a prototype will give me the answer.
Old 25th November 2003, 07:30 PM   #86
peranders's Avatar
The CAD files have left the computer so I start a new thread here.
Bias in a classical current feedback amp - influence how?Hide this!Advertise here!
Negative feedback vs. Time and Classical and Quantum Mechanics. Circlotron Everything Else 18 17th August 2003 01:11 PM
Copyright ©1999-2017 diyAudio
