Old 4th July 2010, 02:27 PM   #1
Default are these heatsinks suitable?????????????
hi every body i have yet another problem ........... heat sinks r becoming costly day by day and becoming hard to find ... i have a bunch of amd cpu heat sinks .... R they any good for amps ....... even if i put 1 heat sink per 2 device will it be ok ... how much heat can these heatsinks dissipate with forced cooling ???????
I am actually planning on making dx blames st can i use these cpu heatsink ???????
regards
aniket
Old 4th July 2010, 02:39 PM   #2
ostripper's Avatar
yes , 1 amd HS for each OP device. These are designed for 50 - 100 watts apiece (processors).
Screw 4 on a piece of 1/8" angle and you can dissipate satisfactorily 2 - 50-60 watt class B amps (4 devices).
For a very hot environment and/or inadequate ventilation use a couple of 80mm PC fans at 7 volts (quiet) to supplement this arrangement.
OS
Old 5th July 2010, 12:30 AM   #3
lanchile's Avatar
[QUOTE=phoenix87;2234859]hi every body i have yet another problem ........... heat sinks r becoming costly day by day and becoming hard to find ... i have a bunch of amd cpu heat sinks .... R they any good for amps ....... even if i put 1 heat sink per 2 device will it be ok ... how much heat can these heatsinks dissipate with forced cooling ???????
Did you check on ebay? they always have hefty heatsinks there and they are not too expensive. in my case, I do not like using fan for cooling the heatsink.
Old 5th July 2010, 01:07 AM   #4
smartx21's Avatar
Send a message via MSN to smartx21 Send a message via Skype™ to smartx21
Default PC heatsinks are OK!
Take a look at what I have done (photo is DX Blame ST!!!).
This is an original AMD heatsink.
But be careful with noise. A fan speed control would be nice in order to reduce unwanted noise, and also for longer life.
I believe that original Intel Pentium heatsinks are much better than AMD's, although they have a smaller area to fit devices.
Tell us later your approaches.
All the best,
Max.
We should not dwell on what we do not have, but, instead, be grateful for what we do have!
Old 5th July 2010, 07:07 AM   #5
thanks smartx21 ............ i actually downloaded ur video from youtube ........... quite impressive can u give a few details .............
1. supply voltage
2. speaker impedance
3. were u running the amp at full power?
4. how hot was the heat sinks ....????
regards
aniket
Old 5th July 2010, 01:50 PM   #6
smartx21's Avatar
Default Enjoy!!!
1. supply voltage
The circuit is original DX Blame ST, fed with 35+35DCV, 8 ohm-speakers (maybe lower than this), I pushed it to the max without any noticeable distortion, but I cannot measure the actual output power (at least I haven't tried so!).
If fan is on, no trouble. No need for fastest speed. As said above, 7V is fine. If you prefer, install a controller, with heat sensor. I can provide two circuits, if you need. But never try to run it without the fan at maximum power!!!
"Enjoy good sonics!", as told by the author.
All the best,
Max.
Old 5th July 2010, 03:43 PM   #7
thanks smartx21 ........... plz provide the temperature controller circuit .......
regards
aniket
Old 5th July 2010, 08:33 PM   #8
smartx21's Avatar
Default Fan Control
This is from Elektor (moderators: may I?).
In fact, I haven't tried this circuit, but it seems to work fine. All you have to do is tune your sensor (you may also try other kind of sensors, depending on your skills).
Other circuit I have is a bit more complex, with a dual op-amp and a RED LED as heat sensor (!!!).
All the best,
Max.
Old 5th July 2010, 08:38 PM   #9
smartx21's Avatar
Of course, you will need 12V from a 35+35V supply, or a separate winding to feed this circuit. If you plan to use speaker protection (delay, short circuit, DC), than you sure will need a separate supply for these sections of the whole project!
Max.
Old 6th July 2010, 01:43 AM   #10
infinia is offline infinia  United States
infinia's Avatar
Ive played around with these fan controller things. They are really a lot of fun and frustrating at the same time, mainly because they tend to turn on and off rapidly because most times it has little to no hysteresis. I recognize that image from Elecktor as one of those "text book" designs that looks good in theory. As soon as the fan speeds up it quickly cools the thermistor, slowing it down immediately, again and again. Better results are to glue the sensor to a large mass like the heat-sink, instead of just hanging it in the airflow. better yet is to use 2 different set points for on to off.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Wanted - 2-4 Heatsinks suitable for Pass F Series Amp Tripmaster Swap Meet 4 31st March 2010 07:17 PM
Intel CPU heatsinks as power output transistor heatsinks? deltavektor Solid State 4 29th November 2009 01:47 PM
Suitable regulated/filtered 4volt battery-valve power supply suitable for 6+ valves? Layberinthius Tubes / Valves 0 11th March 2004 08:49 PM
Are these heatsinks suitable for Aleph 5? Tony D. Parts 11 15th September 2002 02:35 AM
Page generated in 0.12634 seconds (80.51% PHP - 19.49% MySQL) with 11 queries
