Old 3rd July 2010, 07:48 PM   #1
Question INA217 Preamp
I am planning on making a INA217 Mic Preamp for my first diy amplifier project. The datasheet has a schematic (pg7) for a circuit with phantom power. However, I do not want phantom power in my circuit.
I am not sure how many components to remove. Do I just take out the Phantom Power loop or can I also take out R1, R2, C1, and C2?
Also, how would i connect a 1/4" headphone plug cable to the output, would I just connect the tip(+) to vo and ground the sleeve?
Thanks for the help!
Old 3rd July 2010, 08:41 PM   #2
nigelwright7557's Avatar
Leave c1 and c2 in but take out r1 and r2 and r3 and 47uf.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 3rd July 2010, 08:54 PM   #3
2quad is offline 2quad  Norway
2quad's Avatar
Hi Zaki!
This looks a bit ambitious for a first DIY project! Anyway, if you don't want phantom power, delete R1, R2, R3 and the 47uf cap- You can also short C1 and C2 and delete all 4 diodes. You may connect a headphone direct to the Vo output as you suggest, but keep in mind that the output current from the amp may be a little less than what you want!
Old 3rd July 2010, 10:32 PM   #4
What kind of mike are you using? E
Old 3rd July 2010, 10:52 PM   #5
Originally Posted by 2quad View Post
Hi Zaki!
Even though the protection diodes aren't 'needed', it's a good idea to have them in 'just in case'. Nothing sucks like being in the field to record and blow something up and find that the protection diodes might have saved the day. They cost next to nothing and only add a few pF to the input.
Old 4th July 2010, 05:19 PM   #6
Looking a little more at the datasheet I would make 3 very minor changes. Add a small value (22-100 ohms) resistor in series with the output to decouple the amplifier from the cable capacitance. This helps to keep it stable. You may also want to add a potentiometer level control on the output if you're running into a computer. The level controls on my Gigabyte motherboards occur after a buffer stage which can be easily overloaded.
Under very loud conditions that preamp can put out >25 Volts p-p which is not a problem in itself but into a PC could damage the input if the aforementioned level control is turned up. So, the 3rd change would be to add some stacked diodes to limit the output to <5 Volts p-p to protect subsequent devices.
I use a similar preamp for microphones and had to add the level pots to go into a PC but I still have to add the protection diodes. It's another one of those 'real soon now' things.
Old 5th July 2010, 12:57 AM   #7
tiefbassuebertr's Avatar
Default Ssm2017 ssm2019 lt1167 that1510 ina163 ina103
I note, that except the INA217 follow additional pincompatible IC's there are:
SSM2017, SSM2019, LT1167, THAT1510, INA163 and INA103
Here the data sheet URLs:
TT Semiconductor 1510/1512 - Preamplifier ICs
http://web.archive.org/web/200806081...ifier_ICs.html
http://www.thatcorp.com/datashts/THA..._Datasheet.pdf
SSM2017 | Self-Contained Audio Preamplifier | Obsolete | Analog Devices
SSM2019 | Self-Contained Audio Preamplifier | Audio Signal Processors | Audio/Video Products | Analog Devices
Audio Amplifier - Microphone Preamplifier - INA217 - TI.com
Audio Amplifier - Microphone Preamplifier - INA163 - TI.com
Audio Amplifier - Microphone Preamplifier - INA103 - TI.com
Linear Technology - LT1167 - Single Resistor Gain Programmable, Precision Instrumentation Amplifier
Low Noise Balanced Microphone Preamp
and here both commercial preamplifiers and diy projects arround this types:
Rod Elliot Sound Products
Low Noise Balanced Microphone Preamp (discrete solution for SSM2017/INA217)
Trichord Dino
Trichord Research Dino Phono Amplifier (THAT 1510)
http://www.stereoplay.de/Testbericht...b9f74ee127.jpg
Stereoplay, das Magazin fr Hifi, Surround und Musik - Phono-Vorverstärker Trichord Dino Mk II
Lehmann Audio "Black Cube"
krishu.de Lehmann Clone (SSM2019)
Lehmannaudio :: HighEnd vom Toningenieur :: Black Cube Statement (SSM2019)
Simaudio "Moon LP3"
Simaudio MOON LP3 Phono Preamplifier (INA163)
Stereoplay, das Magazin fr Hifi, Surround und Musik - Phono-Vorverstärker Moon LP 3 (INA163)
Clearaudio "Smart phono"
http://www.clearaudio.de/download/ph...stereoplay.pdf (INA163 OPA2228 NE5534)
Hoerwege MC V2
hoer-wege PHONO-MC V2: symmetrischer PrePre für alle MCs (INA163)
Thel Phono X1
http://www.thel-audioworld.de/module/phono/Phono-X1.jpg (INA217P oder INA163P)
Phonovorstufe von THEL
Ulrich Böhmke Audio und Messtechnik Mini Pre II
www.xinxii.com/gratis/107498rd1242149359.pdf (INA163)
Tom Evans Audio Design"The Groove" Phono amp (THAT 1510)
Tom Evans Audio Design Groove phono preamplifier
Tom Evans Audio Design at Walrus Systems hifi website
German thred arround this subject
Unterschiede zwischen SSM2017 SSM2019 LT1167 THAT1510 INA217 INA163 und INA103 für MC/MM Input? - Phono - Restauration und Selbstbau - Analog-Forum
Phantom power INA217 argonrepublic Analog Line Level 0 10th February 2010 08:12 PM
INA217 Blocking capacitors argonrepublic Analog Line Level 0 9th February 2010 02:23 PM
Ina217-drv134 argonrepublic Analog Line Level 2 9th February 2010 07:26 AM
Ina217 drv134 argonrepublic Analog Line Level 1 7th February 2010 06:57 PM
My very first PCB layout - INA217-based mic preamp was the victim 454Casull Analog Line Level 4 27th June 2009 05:27 PM
Page generated in 0.11999 seconds (78.32% PHP - 21.68% MySQL) with 10 queries
