Hi
There is 100 nf capacitor across the emiter resistors of the output transistors. Is those capacitors are another type of suckout capacitors ? Thanx Paul |
#2 |
Your circuit diagram has a few mistakes on it.
The LTP output is shorted to B+ for starters.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#3 |
Hi
Yes, it's shorted to B+ because the 5K6 resistor are in the wrong place. I did not made that circuit. But I ask the question, not to build this amp, but to know about the fonctions of the 100 nf capacitor across the emiter resistors of the output transistors. Thanx Paul Last edited by tessier; 2nd July 2010 at 10:56 PM. |
#4 |
Its very rare to see those capacitors there.
I cant see they are doing very much in parallel with such a small value resistor.
#5 |
Hi
It's first time I seen those capacitors there, where did you seen those in another circuit ? Can it act as a suckout cap to reduce the output transistors switching noise ? Thanx Paul |
#6 |
Did it Himself
It's the base that needs charge sucking out from it. I've no idea what those caps are doing there, sometimes you just see designs with stupid random things.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#7 |
Hi
Yes, there is two types of suckout capacitors that I know, a capacitor across the resistor between the emiter of the two drivers transistors, and the other type are a capacitor across the base stopper resistor of the output transistors. Thanx Paul Last edited by tessier; 2nd July 2010 at 11:23 PM. |
#8 |
Compensate the inductance of a wounded resistor?
| Th. Lösch Phono Amp: Question about IC used & ECC808 to ECC83 | Herr Grau | Tubes / Valves | 45 | 23rd February 2009 11:12 AM |
| do i REALLY need a crossover?? and an amp question. and an ohm question | legendaryfrog | Multi-Way | 4 | 29th October 2006 01:39 AM |
| Multi-room audio system (speakers & Amp question) | dwalter | Multi-Way | 0 | 17th November 2004 07:22 PM |
| old speaker question, bullet midrange question & link to speaker project | wallijonn | Multi-Way | 10 | 5th November 2002 06:03 AM |
| Page generated in 0.09459 seconds (76.87% PHP - 23.13% MySQL) with 11 queries |
