Should I bias my amp while it is cold, or after it warms up to normal operating temp? Since I guess the bias current seems to rise with the temperature. Whatever I do I'm replacing the pots first.
- Nick |
#2 |
After half an hour to an hour.
#3 |
Thanks, i wasn't sure.
#4 |
Some recomend connecting an input signal and a load (speaker or dummy) and running ithat way until the temperature stabilizes. Then disconect the signal and load and set the bias before it cools.
#5 |
After having set up the bias check again after a while!
Repeat this several times. |
#6 |
Electrons are yellow and more is better!
Good idea to really make the amp hot, either by turning up bias (if it's possible) or by high output power. When it's really hot, adjust the bias. Then in cooling process, measure the bias at a few temperatures so you see that it's rather stable or the bias increases slightly with lower temperature. If this is the case the amp will be 100% regarding to bias. It's important that all parts inside have reach stable temperature and this can take 15-30 minutes at least if you include transformers and all big parts.
/Per-Anders (my first name) or P-A as my friends call me |
| Hello from cold Wisconsin | s800 | Introductions | 1 | 13th January 2009 03:31 PM |
| Cold Heat | Apogee | Everything Else | 4 | 12th October 2004 05:04 AM |
| Electronics in the cold | leadbelly | Everything Else | 0 | 31st January 2004 07:42 PM |
| Aleph3 to cold? | Kermit | Pass Labs | 11 | 3rd May 2003 11:41 PM |
| How Cold Is it? | kelticwizard | Everything Else | 17 | 18th February 2003 04:30 PM |
| Page generated in 0.07828 seconds (74.87% PHP - 25.13% MySQL) with 10 queries |
