Old 20th October 2010, 08:05 AM   #721
keantoken's Avatar
Thanks a lot OS!
You could say it is a Rush... Here is a schematic with it grafted on to your PX. No mysterious unpredictable harmonics! The RC comp resistor can be increased for better specs, but there will be a resonance in the loopgain.
- keantoken
Old 20th October 2010, 08:07 AM   #722
keantoken's Avatar
Um, FYI, the outputs can't run at 234W constant power like that. Probably should lower the rails, and parallel outputs. Look at Sander Sassen's ExtremeA amp for how he did this.
- keantoken
Old 20th October 2010, 09:10 AM   #723
keantoken's Avatar
Hey OS, these caps look really interesting. Not SILVER mica, but mica nonetheless.
SOSHIN ELECTRIC CO.,LTD. -PRODUCT INFOMATION-
Got me thinking, maybe SMD pads should be included for compensation caps?
- keantoken
Old 21st October 2010, 05:52 AM   #724
ostripper's Avatar
Default Finished my AX/BX PB60 documentation update.
- keantoken
Those mica's would be REAL cool to SMD (solder direct) B-C for the miller .... no PCB trace required. As of now, I DO keep the miller VERY close to the VAS devices.
I have finalized my standard documentation package with all the "mongrels". I will include a high quality photo like SNG001 did in his PDF for the PS80. This photo will coincide with the schema/overview for ease of construction. Below is an example (pix 1/2 - PB60LP).
The AX/BX are done but are without pictures (tomorrow). I redesigned these "low end" projects .. ha ha... to accept your "junk parts".The AX was almost the top performer in WAHIB's amp shootout with 200ppm THD @ 1K/40v p-p , so "low end" might be debatable ???
Even with new parts, 2 voltage boards can be had for $25USD. Total for a stereo pair AX or BX + PB60LP's would set you back $45-50USD ...much less if you clean out your junk drawers..
All ZIP's that end in "final" are built and have been throughly ABUSED in the "DOGHOUSE". (CXVB1.2 is next)
BTW , the below PB60 is an EXACT copy of your power board(s).. keen , use as a guide when you get your box...
OS
Mongrel website , always current and updated :
http://www.fidelityforce.com/ostripper
Old 21st October 2010, 11:30 AM   #725
sng001 is offline sng001  Australia
Default PB120LP Ver.2 PCB
I have made some minor changes to the PB120LP. The Ver.1 board is being built by Repeet and I found more clearance are need for some resisters. I made some minor changes:
More clearance for R85 & R88.
Relocate R98 & R99 so that they no longer live under the inductor.
Space for bigger output inductor.
Fatter ground trace.
Bigger on-board filter caps - snap-in types up to 25mm dia.
Deleted the Capacitor-multiplier option.
The board is slightly smaller.
I will create the BOM & PDF for the new ver 2 of PB120LP.
Cheers, Stanley
Old 21st October 2010, 12:08 PM   #726
repeet is offline repeet  Australia
Hey Stanley,
I like the improvements on your boards. My semi-conductors arrived yesterday and I have made my PSU inductors. Hopefully I can mount the heatsinks on the weekend and start putting it all together.
Pete.
Old 21st October 2010, 12:24 PM   #727
ostripper's Avatar
Cheers, Stanley
Some layout adjustments.... I HATE D96/97 "crooked" !! Move c88/92 right next to the voltage board interface euroblocks , line up the diodes (d96/97) and the resistors (r75/78) vertical near mounting points.
C99/r99 swap with the G1 takeoff point , as close to the OP coil as possible and long jumper over R96b can be 2 short ones , first right above 96b. You dont need the big 6800uF's on board if you have such a big offboard supply like the PS80/100 , shrink to 1k/63v -12.5 -18mm for more layout room to center G1/2 .. this is more important than big caps , especially for G1 (big "dirty pulses from OPS),
you might even add the blueled (V- 68k Resistor/high efficiency).
Otherwise all is good.
What is the CAD software used ?? SNG.... I only use "head" now.
OS
Old 21st October 2010, 08:50 PM   #728
Hi OS,
Thanks for the tips, I will see if I can change the pickup point for G1.
I did a quick change to D97 so that it is no longer crooked.
I use KiCad which is a free software. I found that the learning curve is not too bad, may be because I used the DOS version of Protel AutoTrax before. The default libraries are good but I already added quite a few of my custom footprints to the user library.
Cheers, Stanley
Old 21st October 2010, 11:30 PM   #729
keantoken's Avatar
OS, I got the box today.
Is there any simple way to clamp outputs to a heatsink using ordinary household materials?
- keantoken
Old 22nd October 2010, 08:16 AM   #730
ostripper's Avatar
- keantoken
Kool... USPS is dang kwik!!
I use these... they are $1-2 apiece at a local ACE hardware store... (below pix1)
for doing either low or high power amps you need 1 - 6-32 tap and 1- 4-40 tap.
you ask the helpful hardware man to select the 2 drill bits for these taps ,...drill the holes and the 4-40 / 6-32 screws cost $0.10 cents apiece.. the NJW's mate with the 6-32 screws , the MJE's mate with the 4-40's along with the right insulator (pix2). the ksa3503 can be directly screwed to the HS.(with HS grease). the taps can be used with oil in the holes ... vice grip , slow turn .. back out , slow turn... you get factory results.
If you must , you can directly screw the NJW's to the HS with metal tapping screws using a mica or silicone insulator. the MJE's are more complicated with the shoulder washer shown in ( pix 2). I would suggest the taps from ace as they give the best results.
PS.. you can obtain the shoulder washers for the mje's from used PC power supplies .. usually 4 in each.
If you need more info I will PRESENT my tapping efforts NEXT on this thread... must do my PB60 "doghouse" amp..
OS
If you lack
Symasym - the next generation (supersym) ostripper Solid State 253 18th August 2011 05:47 AM
Supersym patent Rescue Toaster Pass Labs 6 22nd January 2008 09:49 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
