The MONGREL (supersym II) - Page 186 - diyAudio
Old 7th May 2012, 10:16 PM   #1851
44250 is offline 44250  Serbia
44250's Avatar
Send a message via AIM to 44250
Was it PB120 or a PB250 ,and have you done AX1.3 like this
diyAudio
diyAudio
or like on a first scheme?
Old 8th May 2012, 01:51 PM   #1852
44250: I built the PB250 with an AX1.3 according to the schematic in your post (as it also appeared in late version in this thread). However I reduced the gain somewhat, and the phase maring became to low and caused a slight oscillation. Ostripper helped me to adjust some other components to make it stable (discussed somewhere earlier in this thread). Basically it work very good. Recently I have had problems with the audio sometimes fading away at in one of the two channels, but this I attribute to bad contact/soldering somewhere since the audio back if I knock slightly on the enclosure... Just need to find some time to open the box and do some fault finding
Old 22nd June 2012, 04:44 AM   #1853
naf is offline naf  Indonesia
@44250: any progress of your mongrel build?
Old 23rd June 2012, 04:28 PM   #1854
44250's Avatar
No,not yet... It is on a stand-by for now,i will post as soon as i do something,words and pictures!
Old 20th May 2014, 09:11 AM   #1855
nugroho is offline nugroho  Indonesia
Originally Posted by ostripper View Post
This is what I ended up with. No more changes , it will fit in my nice Altec case.
I just have to label it , run the snot out of it... before I trust it for others. I can't blow my one prototype , so I don't fear the stereo pair. (below)
If alex can come close (but prettier) to the style below - let em' at it.
A long board is the one on my single prototype now , below is the "L" bracket deal.
OS
HAii OS....please share the cooper side...i want to build it
thankyou
nugroho
Old 20th May 2014, 09:26 AM   #1856
thankyou
nugroho
Hi bro.... OS maybe still busy with his new Slewmaster amplifier now.
Regards...
Old 22nd May 2014, 08:38 AM   #1857
Regards...
i guess also like that bro Arif.....hope everything well condition
Old 26th June 2014, 10:18 PM   #1858
mrsavage's Avatar
Default Gerbers files for your supersym and The MONGREL (supersym II)
I would like the Gerbers files for your supersym and The MONGREL (supersym II)
amplifiers so that I can order several sets for building and testing. I you offer a group
buy for either of these amplifiers, let me know. I can either have them done at a
vendor, using the Gerbers files, or purchase them via a group buy. Let me know.
Old 12th January 2015, 12:10 AM   #1859
hajidian's Avatar
good..
Old 12th January 2015, 02:39 AM   #1860
ostripper's Avatar
AX1.3 became the "Honey badger" (DIYA's store amp) and wolverine (slewmaster).
Supersym is the "symasui".
Badger is the true EF2 AX1.3
Symasui / wolverine hook to a EF3 , way better stability -performance.
OS
Amps: http://www.fidelityforce.com/ostripper
Quad core Athlon - Asus essence sound (PCM 1792A) - Slewmaster "Spooky Leach" 200W amp (final favorite).
Symasym - the next generation (supersym) ostripper Solid State 268 3rd November 2016 06:33 PM
Supersym patent Rescue Toaster Pass Labs 6 22nd January 2008 10:49 PM
Copyright 1999-2017 diyAudio
