Old 24th March 2012, 01:14 PM   #1841
smartx21's Avatar
Send a message via MSN to smartx21 Send a message via Skype™ to smartx21
Didn't you consider building the Honey Badger instead of this old Mongrel model?
It seems the selected DIYAUDIO amp is the best of OS's efforts from all the Mongrels versions. Anyone may correct me if I am wrong.
http://www.diyaudio.com/forums/solid...-diyaudio.html
Even though, congratulations for your nice job!
Max.
All the best, Max.
Old 24th March 2012, 09:13 PM   #1842
44250 is offline 44250  Serbia
44250's Avatar
Send a message via AIM to 44250
Max.
I did not know about that one (Honey Badger) ,a friend of mine told me all the best about mongrel so i started it. I have read the most of the topic but there are a few things that i don´t understand
The MONGREL (supersym II)
so,building has stopped and waits for some better times when i get more transistors and electronic adjustable fuse to prevent bourn-outs. Time will tell...
Old 6th May 2012, 09:30 PM   #1843
44250's Avatar
Default AX1,3 final KIT
I got no help about misterious R8 in CX1.3 so i decided to do a copy of a final version AX1,3 and here it is. I sincerely hope that someone will still help me about CX1,3 and R8 problem,just point me where to look or how to think about it.
Old 6th May 2012, 10:42 PM   #1844
keantoken's Avatar
DIYAudio is glitching on me, the thumbnails won't load after licking on them. So I can't look at the schematic. It is possible that resistor could be omitted, or it may be there to lower the dissipation of the LTP current source. In the picture it appears to be 2.2k, and that sounds about right. But I can't see the schematic to be sure...
Old 7th May 2012, 09:57 AM   #1845
44250's Avatar
Maybe this would help? I am not so sure what is the latest schematic but this is what i have:
Old 7th May 2012, 10:18 AM   #1846
I am guessing that R8 is the resistor in the tail of the input LTP, before the CCS.
But the pic is so out of focus I can't read much of it.
What's the point of posting a >500kB pic that can't be read?
Old 7th May 2012, 01:36 PM   #1847
keantoken's Avatar
Yes, I'm sure that's a 2.2k resistor for R8. This resistor isn't needed for dissipation reasons; It was intended to increase the CCS impedance at high frequencies. It does help during fast pulses. I would put it in, but you could just as well short it.
Old 7th May 2012, 01:40 PM   #1848
keantoken's Avatar
44250, have you listened to any of OS's amps? Can you speak on the sound quality? I was present through the design process, and the engineering is impeccable...
Old 7th May 2012, 03:21 PM   #1849
44250's Avatar
Thumbs up thanks! :)
No,this would be the first one and i have started it advised by my friend nikko. He said that "it sounds just like boraomega´s STUDIO SE but on steroids" what was enough for me to start assembling it. (i have STUDIO SE and like the sound of it).
Thank you all so much for help given me here about CX1.3 ,i will post each progres i make. Thank you all so much!
Old 7th May 2012, 03:47 PM   #1850
About sound quality. I built the Mongrel with the AX board and have been living with it since september. I think it sounds very good and also has plenty of power as expected. I am happy with it. However, it would be fun to see how a completed circuit measures. Anyone done that?
Symasym - the next generation (supersym) ostripper Solid State 253 18th August 2011 05:47 AM
Supersym patent Rescue Toaster Pass Labs 6 22nd January 2008 09:49 PM
Copyright ©1999-2013 diyAudio
