The MONGREL (supersym II) - Page 12 - diyAudio
Old 8th July 2010, 07:00 PM   #111
ostripper's Avatar
Keen, read #474 ,then look at the example by mjl21193(post #487). I posted because I got strange results from your asc.
Try the new one , it is nearly optimal. (according to #474)
OS
Old 8th July 2010, 07:09 PM   #112
ostripper's Avatar
Originally Posted by Samuel Jayaraj View Post
I am trying a PCB for your symasym in two parts, voltage and output stage separate. That way it would also be easy to try the Mosfet version which you posted a while ago. Do the driver transistors have to have their own heatsink or can they go with the OP trannies? Thanks.
Two part boards are good , if you tinker , you won't have to rip up the big stuff ! Driver trannies are best on the main HS. It takes the ambient (case , room) out of the thermal comp. A mosfet (verticle irf240/9240) should be the same as my njw0281/0302's. For mosfet , feel free to use mje340/350's as drivers.
OS
Old 8th July 2010, 07:18 PM   #113
ostripper's Avatar
A little messup .."mongrel sim.zip" was the operational simulation. Below is
"mongrel sim2.zip" , which is the loop gain sim.
right click on screen , "add trace" (ctrl +a) , expression -V(vout)/ V(a) ..done.
OS
Old 8th July 2010, 07:46 PM   #114
keantoken's Avatar
Judging by what you may stand to gain, I think you should test it in real life before you condemn it in theory and simulation.
Before and after.
- keantoken
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 8th July 2010, 07:53 PM   #115
ostripper's Avatar
What expression for loop gain ?? I am into gaining anything.
OS
edit : andy c's _x OPS models are not included in mongrel.txt Not a condemnation , just an observation.
Old 8th July 2010, 08:05 PM   #116
keantoken's Avatar
There is a comment under all the simulator commands that contains the OLG trace, I should have indicated it somehow. Plot "-V(vout)/V(vx)".
Sorry everyone, I included the wrong Mongrel.txt in the last upload! Use this one instead.
- keantoken
Old 8th July 2010, 08:41 PM   #117
ostripper's Avatar
I found your old mongrel.txt ... here is what I got (-61db)
why did you add 1khz to v5 ?
below is the loop gain plot I generated.
OS
Old 8th July 2010, 08:48 PM   #118
keantoken's Avatar
Yes, we have the same results.
- keantoken
Old 8th July 2010, 08:54 PM   #119
keantoken's Avatar
V5 has 0V. Frequency doesn't matter since it is only used for OLG analysis.
- keantoken
Old 8th July 2010, 09:03 PM   #120
ostripper's Avatar
I noticed the the lower higher harmonics in the FFT. My concern is the 2 different Cdoms and the effect on stability.
OS
Symasym - the next generation (supersym) ostripper Solid State 268 3rd November 2016 06:33 PM
Supersym patent Rescue Toaster Pass Labs 6 22nd January 2008 10:49 PM
Copyright 1999-2017 diyAudio
