The MONGREL (supersym II) - Page 11 - diyAudio
Old 8th July 2010, 04:54 PM   #101
keantoken's Avatar
Ostripper, see if you can do better than this. Make sure OL phase is at -57 degrees @ 0db so we know you'll get the same results as I did.
- keantoken
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 8th July 2010, 05:18 PM   #102
what do we do with Mongrel.txt?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 8th July 2010, 05:21 PM   #103
keantoken's Avatar
Mongrel.txt contains all the necessary models for the simulation. It only needs to be in the same directory, and LTSpice will use it's contents when it scans the ".include mongrel.txt" command in the schematic. This is included so that the same device models are used whenever the file changes hands. This way we all get the same results.
- keantoken
Old 8th July 2010, 05:25 PM   #104
Bigun is offline Bigun  Canada
Bigun's Avatar
Originally Posted by ostripper View Post
the reason for the 'mongrel" ...A supersym/symasym wrapped in every economical enhancement this site has to offer while still keeping it fairly simple.
My goal is to have the complexity somewhere between a quasi amp and one of the advanced PPM amps (syn08 stuff) , the build to be as easy as a quasi or symasym (perhaps easier).
It seems to me that this could be the 2010 DIY Audio SS reference amp. If so, pcb's from a vendor might be the way to go (no toner transfer).
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 8th July 2010, 05:26 PM   #105
could not open include file "mongrel.txt"
regards Andrew T.
Old 8th July 2010, 05:37 PM   #106
ostripper's Avatar
Hey , keen read post #485 ,#487 ,and #489. Here ... The Frugalamp by OS
It is optimal for the phase to start at 0 dg , slope to a shelf of -90 / -100dg , and not dropping past that until after the unity gain point. Using these rules , I stabilized all the frugalamps and my present supersym (1 year old ).
Detailed explanation is here : The Frugalamp by OS.... Post #474.
Good info ,better sounding with no burning amps since.
OS
Old 8th July 2010, 05:38 PM   #107
keantoken's Avatar
Did you extract the zip file to a folder before you opened it? LTSpice can't look inside zipped folders.
- keantoken
Old 8th July 2010, 05:43 PM   #108
keantoken's Avatar
OS
I haven't a clue what you mean, there is nothing wrong with my file or the way I measure open-loop gain.
- keantoken
Old 8th July 2010, 05:48 PM   #109
ostripper's Avatar
Andrew , here's the latest .. no text needed. Models as directive (on simulation).
By Bigun - If so, pcb's from a vendor might be the way to go (no toner transfer).
Don't want amp of the year. Must make the prototypes (toner transfer) first to probe it to death with my scope and do an audition/tweaking.
OS
Old 8th July 2010, 05:56 PM   #110
keantoken's Avatar
To get the text out of the way right click on it and select "not visible". This hides it without changing the simulation.
- keantoken
Symasym - the next generation (supersym) ostripper Solid State 268 3rd November 2016 05:33 PM
Supersym patent Rescue Toaster Pass Labs 6 22nd January 2008 09:49 PM
Copyright 1999-2017 diyAudio
