The MONGREL (supersym II) - Page 101 - diyAudio
Old 20th December 2010, 12:26 AM   #1001
spind is offline spind  Canada
[QUOTE=MJL21193;2404630
Seriously!
OS, carry on with your efforts. I'll keep my distance and my comments to myself.[/QUOTE]
John,
If you could, it would be great if you could try OS's experiment. I find you both to be very credible and valuable members of this forum, and both able to express strong opinions. You are also similar in that you both can knock out completed projects faster than most people here can get past the planning stages. I don't think either of you post comments lightly, so I think Pete's experiment is worth a try---he seems to have figured the TMC stuff out quite well!
Steve.
Old 20th December 2010, 12:43 AM   #1002
MJL21193's Avatar
I think I'll take a pass on that.
Old 20th December 2010, 12:46 AM   #1003
AKSA is offline AKSA  Australia
Hey John,
No one is criticising, least of all me..... give it a go, mate!
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 20th December 2010, 01:37 AM   #1004
ostripper's Avatar
Originally Posted by MJL21193 View Post
You were doing well until this part:
Seriously!
Well , I'm sorry you were SO offended. I did not state WHO's ears were untrained (or even if ears can be "trained") .. like dogs can. Can't please um' all ..
If what you say is true , there should be no DIYA ... just buy OEM "crap" , since there is no difference anyways ???
On with my "pandering"
First 4 attachments show what LT says about the diode mod ( I don't 100% agree with LT - BTW). To be "action oriented" the last few attachments show a magic current mirror in the making...
last attachments are the real "magic diode" ...
I will give it a go.. enough small, subtle improvements add up.
OS
Wanderer - my travels.... Facebook - davyjones lockre -
Old 20th December 2010, 01:42 AM   #1005
Banned
I might try this diode thing out on my amps. Do you notice any audible difference with and without the diode ?
Old 20th December 2010, 01:46 AM   #1006
ostripper's Avatar
I'll know in 5 minutes..
OS
Old 20th December 2010, 02:12 AM   #1007
Hmmm, Pete, those LT differences are truly insignificant!!
When I did this a couple years back on one of my power amps, I noticed improved refinement and better image focus. Not things you can measure, unfortunately, but worth having.
Awaiting results from your 'mountain ears'!
Hugh
www.aksaonline.com
Old 20th December 2010, 05:32 AM   #1008
ostripper's Avatar
I have listened ... for hours (below - ugly CM's) .... can not note any audible changes with the diode/ CM. I did not let any non-objective statements or opinions sway my decision. Same music , 2 pairs voltage stages (w/diode - no diode BX1.3's) , same power supply/output stage and bias. NO change.
The only real changes were in the static tests , the diode forced current balance down to 1 microamp vs. no-diode 20-30uA. As seen in the LT FFT's , the distortion components were within db's and at the -100db level ... even "mountain ears" could not discern these subtle soundstage changes. Tried the headphones hooked to 220R resistors tied to the OPS ... NO change.
Tolerances of the current mirror degeneration resistors would offset the "micro" improvement of the CM current balance. And , I forgot to mention that the diode made the LTP LESS balanced in LT (slightly level shifted it). So ... thumbs down.
Edit: where this "diode trick" DOES seem to have major effects, is in a non-beta enhanced VAS where the CM/LTP sees more load (also according to LT).
OS
Old 20th December 2010, 06:40 AM   #1009
Thanks Pete,
Much appreciated. It seems that for most purposes the diode is a waste of time. That's good; it eliminates one more component, and one less part is less time and expense to make and more reliability as well.
Hugh
www.aksaonline.com
Old 20th December 2010, 07:10 AM   #1010
ostripper's Avatar
Originally Posted by AKSA View Post
Thanks Pete,
Hugh
Except for a single device VAS , is that what you did your experiment on ?
Perhaps that is the reason for different results.
The beta enhancement makes the load on the CM miniscule (see below). A 40uA/20mV - current /voltage change will swing the VAS to 110V p-p. This is with a standard KSA992/KSA1381 BE-VAS (AX/BX).
OS
Symasym - the next generation (supersym) ostripper Solid State 268 3rd November 2016 05:33 PM
Supersym patent Rescue Toaster Pass Labs 6 22nd January 2008 09:49 PM
Copyright 1999-2017 diyAudio
