The reverse engineered power amp circuit of A1 2008 edition is published in a Chinese magazine. The output devices are STD03P/N. I simulated in LTspice with discrete Darlington. The performance is very promising. The amp uses two-pole compensation to achieve good THD performance. I am going to build a test board.
The simulation circuit is shown here. R25 and 26 are not present in the actual circuit. |
#2 | |
I will follow you close with this project, since I can learn a lot from your experiences. Especially the biasing, because I failed to let the STD03's work well with high bias levels. I look forward to see how you going to make it work Good luck! With kind regards, Bas |
#3 | |
D4 and D5 are used for biasing the output in Class A. I will be very careful with STD in high bias. Panson |
#4 |
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Curious about those two input transistors. Is there a special reason to use ZTX757s and not to degenerate them with R25 and R26? As far as I could recall from Doug Self's book, the only downside for degenerating the input LTP was a noise penalty. But you can't be aiming for ultra-low noise here as your feedback components are fairly high impedance and you're running only 700uA into the tail. Are you intending to run at much higher voltages? - that would explain choosing 300V transistors for the input stage.
I think ideas are what you want to get rid of. I don't really like songs with ideas. - Leonard Cohen |
#5 | |
#6 | |
Well, I will compare the performance between with and without degeneration when I build a prototype (and simulation). |
#7 | |
. I'd be inclined to make some improvements myself if laying out a PCB. Definitely include spaces for those resistors - they'll improve the slew rate and may even help in RF rejection (my favourite hobby horse
#8 | |
Do you think that the STD used as conventional Darlington (omitting diode stack) will have problem for high bias? If the problem is solely due to diode stack temp coeff difference from that of the transistor, we should be able to find a proper diode stack current for good thermal tracking. On the other hand, is Darlington not good for Class A operation since the driver is "over" heated by the output transistor. Have you seen/tried other Darlington for Class A operation? Panson |
#9 | |
I've never seen a Darlington for class A operation till you showed me the A1 2008 edition schematics. I was aware though that Musical Fidelity builds even bigger class A amps with the STD03 device. In a very optimistic attempt to make my own STD03's class A I failed the hard way, and blow them up many times. Not because of oscillation, but because of thermal run away. The amp goes into a thermal loop and heat up very rapid. But, assuming the A1 2008 edition works good, it seems it must be possible with the STD03's. I just don't have the skills to make it happen in class A with those devices. I hope you provide the solution EDIT: Maybe I overlooked it, but a bit tricky is indeed we don't know the hFE and the current ability of the build in drivers. Makes it indeed more tricky. But then again Musical Fidelity did it... With kind regards, Bas Last edited by Sebastiaan; 23rd June 2010 at 01:34 PM. |
#10 |
| FS: Musical Fidelity X-A1 Intergrated Amp | ChrisR1983 | Swap Meet | 2 | 20th June 2010 06:14 PM |
| Musical Fidelity A1 Improvements | juluska | Solid State | 17 | 8th February 2010 12:37 PM |
| Musical Fidelity X-A1 Modification | adfairless | Solid State | 7 | 31st December 2006 01:12 PM |
| Musical Fidelity A1 Heatsink | Assesears | Everything Else | 5 | 17th February 2004 07:45 AM |
| JLH Or Musical Fidelity A1? | Jay | Solid State | 1 | 16th September 2003 12:40 PM |
| Page generated in 0.13355 seconds (80.23% PHP - 19.77% MySQL) with 11 queries |
