Can anyone tell me what is recommended bias voltage for Rotel RB1080?
Thanx in advance. |
#2 |
adjust VR 601 while monitoring voltage between TP1 and TP3 for 7 mv (millivolt ) reading for one chanel
adjust vr 602 while monitoring voltage between TP2 and TP4 for 7 mv ( millivolt ) reading for the other chanel regards sakis ( information for the available service manual )
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#3 |
Hi Sakis, wrong thread etc. but RA 1060 Rotel - similar? There's no urgency, its an old job never completed.
regards |
#4 |
sure Ian ....what can i do for you ??? service manual or adjustment procedures ??
#5 |
Wow, that was quick, quick service hehe.
It was the bias setting which I stupidly didn't check for before replacing output Txs. I thought you may have had this one in the file for RB1080 too. thks
regards |
#6 |
well Ian its not the exact same thing ...see attachment please that is a part of the service manual ... ( e mail me i f you want it ) ( for the 1060 ...its not in the same file with 1080 works diferent )
kind regards sakis
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr Last edited by sakis; 20th June 2010 at 01:01 PM. |
#7 |
I think with those figures and warm-up note it should be fine thank you very much, Sakis. I had presumed 12mv and now I know better. Thank you too for the offer of manual details. Can I offer you a beer or would you like something better?
regards |
#8 |
i am fine Ian thanks....i would be actually tempted to listen to it either way 5 or 12 mv and for sure it will run hotter with a bit nore bias ....
often if i service amps that are supposed to used from normal people and no party animals i try to keep that bias up ( up means to a reasonable up ) kind regards sakis
#9 |
just been looking at the schematic of the 1080 and i ve seen that is a 200w very symmetric and inetersting amplifier but still doesnt use any vi limmiter for the output section nice approach for a hifi machine but not really safe for this ammount of power ...
if the power supply is good that design will easilly produce 200w at 8R and almost double at 4 ( even though specs say 300 and that is not really possible without any limmiting ) so either the supply is poor or the estimation is academic still remains an interesting amplifier
#10 | |
| Setting idle Rotel RA-870BX or Service Manual | iMac | Solid State | 2 | 26th April 2010 11:02 AM |
| Rotel RB1080 Schematic | Al Raj | Solid State | 3 | 20th September 2009 10:28 AM |
| Rotel RB1080 - Injured, needs consulting specialist | Maxi11235 | Solid State | 11 | 28th May 2009 04:39 PM |
| Setting Bias | kptseng | Solid State | 9 | 8th March 2008 01:56 AM |
| bias setting | ben goh | Solid State | 8 | 14th August 2006 04:26 PM |
| Page generated in 0.11487 seconds (80.07% PHP - 19.93% MySQL) with 11 queries |
