diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   MOSFET amplifier schematic and PCB needed (http://www.diyaudio.com/forums/solid-state/168814-mosfet-amplifier-schematic-pcb.html)
dolhastelian 18th June 2010 08:07 AM
Hello everybody,
I'm quite new to this forum.
I have built some years ago an amplifier that hasn't gave me any listening satisfaction. It was built around TDA 7250 + Darlington transistors(does not work well, the transistors are very hot even without any input signal, or at low level).
I want to replace the power stage with a discrete MOSFET amplifier.
I have a power supply of +/- 35V available (toroidal transformer 500W, bridge, filter capacitors: 2x10000 uF).
I saw a lot of threads on discrete amplifiers.
Could someone suggest me a good amplifier (60-100W) with good performance (very low THD: < 0.001) that was built already by someone and eventually has PCB?
Thanks to all !
AndrewT 18th June 2010 09:50 AM
try ESP
riktw 18th June 2010 09:53 AM
hello
look at this amp:
60-80W Power Amplifier
you can buy the PCB's on the website, it performs good and dozens of people already made that design.
and with PCB's it easy to build :)
smartx21 18th June 2010 10:25 AM
Another configuration
2 Attachment(s)
What about changing the output transistors with a different configuration, without darlingtons?
As stated in the original source, "Q1~Q4 is driver transistor to drive Q5~Q8, a SANKEN transistor. Power supply is 40V, and will give 100W power".
I think you can use your supply without changes.
Just tell us what happened afterwards.
Max.
Bill Fuss 18th June 2010 11:35 AM
Originally Posted by AndrewT (http://www.diyaudio.com/forums/solid-state/168814-mosfet-amplifier-schematic-pcb-post2220126.html#post2220126)
try ESP
I built the P101 a couple yrs ago. It's a very competent amp and easy to scale for any power you wish. 35v rails would be fine.
dolhastelian 18th June 2010 11:52 AM
I found Symasym project on the web.
Has anyone built this amp?
Are the specifications real?
I would like to built it. Any comments?
Thank you!
juma 18th June 2010 01:39 PM
There are many threads here about SymAsym, a lot of guys built it, and yes, it's a great amp.
dolhastelian 18th June 2010 03:24 PM
Thank for the encouragement.
To everybody:
Please reply if you built Symasym.
Can I start to build it without any modifications, only using the information on the project site?
Which version to build? 5_2 or 5_3 ? THD for 5_3 is better, they say, is it?
Is the PCB ok?
stoN_Cold 18th June 2010 04:14 PM
Simple & cheap
http://www.diyaudio.com/forums/solid...velopment.html
Regards zeoN_Rider
AndrewT 18th June 2010 04:21 PM
the Symasym is not MosFet.
Resources saved on this page: MySQL 18.75%
