Old 16th June 2010, 04:23 PM   #1
Federmann's Avatar
Send a message via ICQ to Federmann Send a message via Skype™ to Federmann
Default amp 1000W/2000W, IRFP240/9240
My last 1000W (2000W) amp, PCB 40x270mm, 10 x IRFP240/9240 (2 x PCB 40x270mm, 20 x IRFP240/9240 )
Old 16th June 2010, 08:54 PM   #2
nigelwright7557's Avatar
Any chance of a schematic ?
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 17th June 2010, 04:27 AM   #3
Federmann's Avatar
Here Schema
Old 17th June 2010, 07:43 AM   #4
sakis is online now sakis  Greece
sakis's Avatar
often pcb designers have a fiction or a vice with symmetrics and size ( including me ) ....playing this game might end up with an ultra compact and symmetric pcb but that comes with a a couple of troubles
one : that no one can use a bigger semi for the output if exist or if needed
two: keeping so many output semis so close to each other means that the heatsink has to be made of zorex, kryptonex, starson or any other material from the moon or jupiter to be able to absorve this type of heat ...
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 17th June 2010, 09:43 AM   #5
Xoc1 is offline Xoc1  United Kingdom
Xoc1's Avatar
Federmann
Has anyone ever built this layout and effectively cooled it?
I am strugging to envisage an efficient heatsink layout to suit.
Maybe a re-design is required to the layout of the output mosfets to suit the real world.
For a working example, look at Quasi's designs which are documented on his website
Quasi's DIY Audio Site
Old 17th June 2010, 10:16 AM   #6
Aldotin's Avatar
10 pair of IRFP mosfets driven by the VAS directly?!
Old 17th June 2010, 12:02 PM   #7
homemodder's Avatar
Not even 2 pairs should be driven directly from the vas
Old 17th June 2010, 03:25 PM   #8
Federmann's Avatar
There is no reason to give more of the transistor.
Old 17th June 2010, 03:30 PM   #9
It depends on how much current goes through the VAS.
I have succesfully used 3 pairs with just a VAS driver, the frequency response was fine over the audio range.
Old 17th June 2010, 03:37 PM   #10
Federmann's Avatar
Originally Posted by Xoc1 View Post
Federmann
8 pairs and 2x500W
IRF540/9540 or IRFP240/9240 Ermac Solid State 18 13th January 2012 01:06 AM
IRFP240/9240 amp Schematics Zero Cool Solid State 8 25th May 2009 03:38 PM
Irfp240/9240 A75 PassFan Pass Labs 4 6th July 2008 02:58 PM
LME49830 And Parallel IRFP240 9240 audiobot Chip Amps 7 29th June 2008 10:58 PM
IRFP240/9240 -Vbs,Drivers ??? zox2003 Solid State 42 4th April 2005 06:37 PM
Page generated in 0.11801 seconds (78.84% PHP - 21.16% MySQL) with 11 queries
