amp 1000W/2000W, IRFP240/9240
Old 19th June 2010, 08:52 AM   #21
Federmann is offline Federmann  Czech Republic
Federmann's Avatar
Send a message via ICQ to Federmann amp 1000W/2000W, IRFP240/9240
Originally Posted by wahab View Post
well, it s doable if one is satisfied with a THD ratio that
is ten fold higher than when adding an EF buffer stage....
Charts will tell maybe
Old 19th June 2010, 09:33 AM   #22
PMA is offline PMA  Europe
PMA's Avatar
Originally Posted by Federmann View Post
Please do not measure THD at 1kHz, measure, please THD at 100kHz. Many transistors does a very slow amplifier.
Okay, here you are. Would you kindly show your THD measurement at 100kHz.
Old 19th June 2010, 11:42 AM   #23
Coastben is offline Coastben  Australia
OI OI OI
I think we need to remember that when driving even a single pair of VERTICLE FETS, we need a fair wack of current across their gate to keep them stable. They need to be driven tightly! 10 Pairs - This needs to be thought about carefully! HF Distortion will be up the shoot... I reckon an MJE350/340 will do the driving nicely! Better yet, MJE15032/33.
Nice Layout though - 5*s
On the front of cooling... In one lot of amplifiers I designed, we ended up with 2 x 2000W RMS in a 2U package, so needless to say we needed to get rid of a lot of heat! Two things emerged from months of idea's... Increase the number of output devices - ie use way more than you need, which as we all know will drop the total heat dissapation dramatically, and number 2 : We got a car radiator company to build a run of mini radiators. these fitted in a 2U case and were very efficient at cooling. The answer is to have a very thick piece of material for the output devices to mount onto. 4 x 80mm fans attached to each "heat sink" for forced cooling. These were mounted against the sides of the case, an blew he hot air out, sideways. Just about the entirety of the side panels were vents, to obtain as much free flow as possible.
It did the job in around 300 touring amplifiers.
Old 19th June 2010, 11:45 AM   #24
Workhorse is offline Workhorse
Workhorse's Avatar
Originally Posted by Coastben View Post
On the front of cooling... In the lat lot of amplifiers I designed, we ended up with 2 x 2000W RMS in a 2U package, so needless to say we needed to get rid of a lot of heat! Two things emerged from months of idea's... Increase the number of output devices - ie use way more than you need, which as we all know will drop the total heat dissapation dramatically, and number 2 : We got a car radiator company to build a run of mini radiators. these fitted in a 2U case and were very efficient at cooling. The answer is to have a very thick piece of material for the output devices to mount onto. 4 x 80mm fans attached to each "heat sink" for forced cooling. These were mounted against the sides of the case, an blew he hot air out, sideways. Just about the entirety of the side panels were vents, to obtain as much free flow as possible.
Similar to ARX amplifiers from austrailia?
Old 19th June 2010, 11:50 AM   #25
@ Workhorse
Not sure about that, as I have not seen them yet... I was in South Africa at the time.
I know that the crown CSL range had something similar going on with an aluminium heatsink with really thin fins, and air being forced out through the side of the case. The ones we build looked exactly like a radiator, however, the company who made the cooling units advised that copper was more efficient because of the space constraint.
Old 19th June 2010, 11:54 AM   #26
Workhorse's Avatar
Have a look, they also use radiator fins.
Old 19th June 2010, 11:55 AM   #27
Yep... Something Like That! :-)
Old 19th June 2010, 11:57 AM   #28
Workhorse's Avatar
Seems like many followed this scheme
Old 19th June 2010, 12:01 PM   #29
Got to love how the PCB has been cut around the Toroid....:-) You would want to make sure your design was right the first time.
I still think that a radiator style cooling device is the go if you are trying to get rid of loads of heat quickly. The only limit is how tightly they can pack the foils between the plates, and how many high velocity fans you can attach to it!
Old 19th June 2010, 12:13 PM   #30
@ Workhorse
Check your inbox - PM
amp 1000W/2000W, IRFP240/9240Hide this!Advertise here!
IRF540/9540 or IRFP240/9240 Ermac Solid State 19 21st May 2015 03:06 AM
IRFP240/9240 amp Schematics Zero Cool Solid State 8 25th May 2009 03:38 PM
Irfp240/9240 A75 PassFan Pass Labs 4 6th July 2008 02:58 PM
LME49830 And Parallel IRFP240 9240 audiobot Chip Amps 7 29th June 2008 10:58 PM
IRFP240/9240 -Vbs,Drivers ??? zox2003 Solid State 42 4th April 2005 06:37 PM
