What are the pros and the cons of those 3 vas ? - Page 2 - diyAudio
Old 28th September 2010, 10:24 AM   #11
Hello
Wich one are better between the VAS E (buffering VAS collector...) and F (the bootstraping VAS load R) in the image I include ?
I've try the VAS E (buffering VAS collector...) in simulation, but connecting the collector of the buffer transistor to the upper rail did not work correctly.
For now I mostly use the VAS F (the bootstraping VAS load R), and I just found out today, in simulation, that raising the 220 ohm R up to 8K ohm reduce the gain and the distortion of the VAS and amps.
Thank
Bye
Gaetan
Old 28th September 2010, 12:59 PM   #12
ostripper's Avatar
By CBS240- However cascode has wonderful benefits. For starters it allows you to use a lower Vce small signal device for the current amplifier and this brings out all kinds of possible components. Lower Vce transistors tend to have higher Hfe, much faster GBW and lower noise, and it does not add an extra stage in the CL.
This all translates to better sound. Sort of a blend between the beautiful mids and highs of the symasym and the tight bass of a fully complimentary design.
you can "dial in" as much early effect as you want with a "magic resistor" between the current amp and cascode. As far as rail loss , try to set your cascode voltages to 2V minimum under rails (green/blue led) , I have even seen double diode setups (luxman).
By andrew T. If Cascode is adopted, it must drive a high impedance load, either a buffer or a 3stage output.
My GX has no problem with a standard EF2 , all the way up to 120v P/P with a 4R load (transient only). I run a 5ma VAS . Who would need 40ma+ ?? Being more complicated and taking up space ...?? With correct layout, the current amps and cascodes are "back to back" on the same heatsink taking up no more space than a "blameless" , you might need a couple sq. CM's to add your zeners/led's ... not a real issue.
OS
Amps: http://www.fidelityforce.com/ostripper
Quad core Athlon - Asus essence sound (PCM 1792A) - Slewmaster "Spooky Leach" 200W amp (final favorite).
Old 28th September 2010, 04:34 PM   #13
CBS240 is offline CBS240  United States
CBS240's Avatar
For me, I try to avoid any Early effect if possible. Keeping less than 8-10V across the current amp transistor should prevent this, but cascode effectivly straightens the Ic vs Ib relationship. Even for the low Vce HF devices, Early voltage is usually higher than 8V. With 10-12V above the power rail, one could leave Vce of 6-7V on the current amp and set the cascode voltage to a few volts above the max Vin for the output follower, and use a clamp + resistor so as not to cause the VAS current amp transistor or the driver to saturate at clipping.
All the trouble I've ever been in started out as fun......
Old 29th September 2010, 12:15 AM   #14
AKSA is offline AKSA  Australia
Pete,
The issue with the cascode is the very high Zout; this means that variations in input impedance of the output stage will have profound influence on the voltage output.
I favor the buffered VAS; this has the advantage of greatly reducing VAS to 1 or 2 mA, and the buffer then gives very low Zout, around 2.5R for 10mA, which will easily power through any impedance variations in the drive to the output stage.
All these approaches can work very well in terms of sound quality. I have found the magic resistor (cf. Peufeu) best with a 200mV drop, and have made cascodes work well in the past. But I keep coming back to the very high Zout, which of course is also a problem for the single, unbuffered VAS.
Another one to consider is the CFP VAS. These can work very well too.
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 29th September 2010, 01:02 AM   #15
forr is offline forr  France
forr's Avatar
Gaetan's thumbnails :
In "e" the 220 Ohm resistor is bootstrapped by the emitter follower, itself loaded by a CCS : the 220 Ohm presents a high load to the VAS.
In "f", the VAS is loaded by a first CCS and followed by an emitter follower conventionnaly loaded by a second CCS. So "f", with its two CCS's, has more components than "e".
Some time ago, there was a question about the difference of quality between "e" and "f", and there was no response.
According to Self, "e" is more distorting than "f" :
Discrete design: More on 2-transistor shunt-feedback amplifiers
Having used a bootstrapped resistor in the VAS of his Mosfet amplifiers, Mike Renardson found that, for ultimate performance, this resistor should be replaced with a CCS, which, in fact, turns out to be a bootstrapped CCS. Its implementation needs a bit more of voltage drop than the 0.6 V across the previous resistor :
MJR9
Some simulations tend to show that the circuit of a VAS loaded by a bootstrapped CCS itself loaded by a second CCS (like in Renardson's scheme) gives slightly lower distorsion than "f". This is quite normal as its first CCS
has almost constant voltage across it. It may also have a superior PSRR.
Old 29th September 2010, 07:58 AM   #16
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
I've tried both.
1. A 'buffered' VAS (C from Self above) simply gives better VAS linearity because the extra small signal transistors raises the VAS loop gain enclosed within Cdom. The correct name for this is a 'beta enhanced' CE VAS stage. Simple and works well on fully complementary designs with resistive LTP loading as well.
2. Cascode ('d' in Self Above). I have an amp running with this - fully complementary design. Zo is high, but the trick it to feed the VAS into a triple EF output stage. Re the 'magic resistor' you can also use this resistor as a current limiter for the VAS when the output stage current limiting kicks in.
3. Others - have'nt tried them, but my next power amp will use a Hawksford cascode.
bonsai
Amplifier Design and Construction for MUSIC! http://hifisonix.com/
Old 30th September 2010, 05:56 AM   #17
Hello
I did try other VAS, I've found the beta enhanced VAS (image C) harder to stabilise with low value cdom capacitor, and the VAS buffered collector (image E) was not work as I expected.
So I've go back to the bootstraping VAS load R (image F) , but rainsing too much the value of R (the 220 ohm resistor) cut the current to the VAS transistor collector and cut a lot the bandwith of the KSC3503 VAS transistor. A resistor R of 220 ohm are quite right since the VAS transistor and the buffer transistor will have quite same current but maby the buffer one need more current than the VAS one.
Bye
Gaetan
Old 30th September 2010, 06:37 AM   #18
Hello
Here is one of my amp using the bootstraping VAS load R (image F), a standard Lin topology with matched LTP transistors and phase lead cap, etc.. It sound very good.
I'm not sure, but is the buffer transistor should need more current than the VAS transistor ?
In this amp schematic the VAS transistor have 3 ma and the buffer transistor have 4 ma.
Bye
Gaetan
Old 30th September 2010, 06:49 AM   #19
Gaetan,
I would use a smaller, higher GBW device like the 2SC1845, run it at 1.5mA to avoid too much dissipation, and use more like 8mA on the buffer for maximum drive to the output stage. This is the GBW curve:
Hope this is helpful,
Hugh
www.aksaonline.com
Old 30th September 2010, 07:18 AM   #20
lineup is offline lineup  Sweden
lineup's Avatar
One advantage as I can see for a normal Darlington instead of Q7/Q5 Sziklai
is that the first transistor, Q7, can have a constant collector voltage.
That is when collector is connected to Ground or even V+
(Most common is Ground, like e.g. Self does in Blameless)
Constant collector voltage can be achieved evenso when using Sziklai, like in Gaetan's schema.
We can cascode Sziklai. Either cascode only Q7 or put both transistors inside the cascode.
I do not know eventual benefit in Gaetans VAS,
but I have cascoded Sziklai sometimes with very good simulation results.
Other times there were no benefits, or even made things worse.
lineup
what are the pros and cons of valve amps? pkgum Tubes / Valves 24 26th January 2014 06:34 AM
Cons / Pros Borat Tubes / Valves 34 1st September 2009 01:52 PM
2 way + active sub in same cabinet pros and cons? FE3T Multi-Way 6 12th September 2008 11:34 PM
Pros and Cons of this technique? G Tubes / Valves 35 23rd October 2003 06:37 PM
tweeter offset: pros and cons gary f Multi-Way 6 15th August 2003 08:57 PM
Copyright 1999-2017 diyAudio
