What about a grounding scheme as follows.
Given separated grounding points in the amp PCB for input, decoupling, speaker return... The idea is not to mix the different currents in an unique wire. The half way points shoud be at the same potential provided the conductors are homogeneous all the way long... Could that be an improvement compared to the unique ground star point. What do you think? |
#2 |
in commonly used dual polarity supply, single ended output Class B/AB you have half wave output current completing in the pos/neg supply cap alternately - current and the Vdrop in pwr gnd Z branches will not be "balanced"
| understanding star grounding | digi01 | Power Supplies | 481 | 13th February 2012 05:38 PM |
| Confusion about star grounding? | semi932 | Power Supplies | 6 | 27th May 2010 04:47 PM |
| Question about Star Grounding | voivodata | Tubes / Valves | 2 | 20th March 2007 07:46 PM |
| Star Grounding Questions | LHMAudio | Solid State | 5 | 12th May 2006 04:31 PM |
| Star grounding in PSU | alexl | Power Supplies | 10 | 7th April 2005 08:46 PM |
| Page generated in 0.08732 seconds (61.14% PHP - 38.86% MySQL) with 11 queries |
