Old 8th June 2010, 08:00 PM   #1
knl is offline knl
Default Magnetic Enclosure and Solid State amps
Hi All
I am busy building a Velleman pre-amp kit and have purchased a steel enclosure and accompanying tranformer at the same time.
I then realized that the enclosure is magnetic.
I know that it is a bad idea with valve amps that have an audio transformer, but does it make a difference on a solid state devices? I have shielded wires for connections.
Thanks in advance!
KNL
Old 8th June 2010, 08:34 PM   #2
nigelwright7557's Avatar
The steel case is a steady state magnetic field and so wont cause AC induction into your wiring system.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 8th June 2010, 08:40 PM   #3
knl is offline knl
Hi Nigel
Thanks for the response, but just to be sure, should I be worried that the power transformer inside the enclosure (I plan to host both the transformer and preamp circuit in the same box) induce a magnetic field in the enclosure and in turn into the wiring system?
Old 13th June 2010, 04:55 AM   #4
DCPreamp's Avatar
As long as nothing shorts to the chassis, which goes for any hardware, there is no problem whatsoever between steel and transformers.
Consider that huge quantities of commercial power amps, preamps, A/V receivers, CD players, etc. all use stamped steel enclosures with internal transformers with zero issues.
If your project fits in the enclosure and you follow safe construction practices, you are good to go!
Enjoy!
Paul
"Believers cling to the myth despite the evidence, reinterpret the myth to suit the evidence, or lie about the evidence to support the myth." "To err is human; to blame errors on external factors is even more so."
Old 13th June 2010, 10:44 AM   #5
AndrewT is online now AndrewT  Scotland
this is not a recommendation just my (in)experience.
I have never been able to make a steel chassis power amp as quiet as a no chassis power amp.
regards Andrew T.
Old 13th June 2010, 02:23 PM   #6
Gordy is offline Gordy  United Kingdom
Knl, steel is absolutely fine, just follow a few basic guidelines…
Ground the case to the mains input ground at one point
Do not use the chassis for audio signal return paths
If using an E-I type transformer, ground the transformer mounting frame
Insulate audio signal input sockets from the case
Space circuit boards away from the chassis a few mm
If you are concerned about radiated field from your transformer consider placing it behind a partition. A sheet of 20 awg steel should be useful in this regard, but it must be well grounded.
Op Amps in Solid State Guitar Amps MrGuitardeath Instruments and Amps 1 11th February 2004 07:43 PM
solid state amps dj_hendo Solid State 0 26th January 2004 12:24 PM
Tube vs solid state amps chrille Tubes / Valves 5 7th August 2002 03:40 AM
Power Suplies for solid state amps promitheus Solid State 11 17th May 2001 11:08 PM
Page generated in 0.08449 seconds (74.49% PHP - 25.51% MySQL) with 10 queries
