Okay, so I am looking at a voltage feedback opamp connecting the output with the input of an amplifier (inverting configuration).
Why such servo is not too common? If the answer is price-to-performance ratio, well, I have too many opamps lying around. It couldn't be the reason. Now that I'm re-thinking to build Mooly's amplifier, it came to me to use a servo to "any" amplifier I'm going to build. Why not? It can not hurt, yes? Okay, you may think of another way to null the output, i.e. proper matching. So now do I have to think of the minimum output voltage where the servo is advisable? Actually I just want to use the servo regardless of the measured output Vdc (Eliminating the feedback capacitor is not a priority to me). What kind of sound degradation you can expect from such servo? What kind of amplifier topology you cannot implement the servo in? Thanks. |
#2 |
DC servos are not too hard to implement, but care must be used with the frequency response. Make sure the time-constant is very long - like from 1Hz or even 0.1Hz to prevent oscillation. When designed well, they will not degrade the amp's sound at all.
DC servos are not too common because they can be eliminated by the proper use of caps for blocking DC and reducing gain at low frequencies. DC coupling is basically audiophile hype, IMHO, because as 99.99% of the audio industry, including recording studio equipment, know that caps when properly used are inaudible.
"Believers cling to the myth despite the evidence, reinterpret the myth to suit the evidence, or lie about the evidence to support the myth." "To err is human; to blame errors on external factors is even more so." |
#3 | |
In this case I have an intuition that the servo has superior effect for the enjoyment of the sound. |
| Help with DC Servo for Current Feedback Opamp | klewis | Chip Amps | 31 | 4th June 2010 05:18 PM |
| Where to put DC feedback for a servo integrator | rtarbell | Solid State | 2 | 26th August 2006 03:00 AM |
| Servo-feedback Subwoofer | dswiston | Digital Source | 25 | 26th October 2005 05:07 AM |
| Bandpass box with servo feedback??? | Circlomanen | Subwoofers | 0 | 16th August 2005 04:30 PM |
| Current-Sensing Servo Feedback | BAM | Multi-Way | 1 | 24th February 2004 10:18 PM |
| Page generated in 0.07307 seconds (79.26% PHP - 20.74% MySQL) with 10 queries |
