Adcom preamp repair -- advice needed Adcom preamp repair -- advice needed - diyAudio
Old 8th June 2010, 04:40 PM   #1
IshMEL is offline IshMEL
Default Adcom preamp repair -- advice needed
Hi all,
I have an Adcom GTP-400 preamp that I need to get repaired. (Output on left channel is intermittent / scratchy.) Does anyone have advice on where I should take it (or send it) for repair? I live in NYC and so I could take it to one of the authorized places listed on the Adcom site, or I could box it and send it. I was hoping for a recommendation for a reliable and cost-effective repair shop.
Thanks for your help!
Old 8th June 2010, 09:06 PM   #2
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Why not have a go at fixing it yourself ?
A pre amp is usually easier to repair than a power amp as a power amp is a loop.
You can follow a signal through the preamp until it disappears or you find a DC fault.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 12th June 2010, 01:47 AM   #3
DCPreamp is offline DCPreamp  United States
DCPreamp's Avatar
I agree with nigelwright7557. You very well may be able to fix it with never touching a soldering iron or pulling the PCB from the chassis.
An intermittent / scratchy channel is likely a dirty pot, switch, or RCA jack. Pick up some contact cleaner (mail order or Radio Shack), spray the volume/balance pot and all switch contacts. After spraying, run the pots and switches full-sweep from stop to stop to fully wipe the contact surface. Also look at the RCA jacks closely looking for the center contact to have deformed, loosened, or backed out. Needle-nose pliers can often fix that.
You'll very likely fix it and learn something too. If that doesn't work, check back here for more options.
"Believers cling to the myth despite the evidence, reinterpret the myth to suit the evidence, or lie about the evidence to support the myth." "To err is human; to blame errors on external factors is even more so."
Adcom preamp repair -- advice neededHide this!Advertise here!
Help-Acurus A-250 amp repair advice needed - long. hafp Solid State 10 18th January 2016 08:06 PM
TEAC VRDS-10 repair advice needed StirlingSteve Digital Source 6 3rd April 2011 08:10 AM
adcom GFA565 repair needed ctk Solid State 1 13th December 2008 05:19 PM
Adcom 555 II advice - repair? test? CBRworm Solid State 15 26th November 2008 07:03 PM
A bass boosted preamp or buffer advice needed Dxvideo Chip Amps 12 27th June 2007 06:54 AM
Copyright ©1999-2017 diyAudio
