Parallel output with/without matched devices
Old 8th June 2010, 07:56 AM   #1
panson_hk is offline panson_hk  Hong Kong
panson_hk's Avatar
Default Parallel output with/without matched devices
I am running simulation to evaluate distortion structure of a push-pull emitter follower stage. It has four-pair devices in parallel. In order to simulate unmatched pairs, I have one circuit having different NPN devices: NJL3281, MJL21194, MJE340 and 2N2055. All PNP are NJL1302. Simulation results show that perfectly matched output THD is slightly higher than that of unmatched output. On the other hand, unmatched output has more energy locating at higher order harmonics.
Vbe of different NPN is slightly difference. Hence, we have cross-over distortion of each NPN/PNP arm difference slightly. Will it lead to some sort of cancellation?
Real circuit shows similar results?
Figures: LTspice schematic and FFT of V(out1) matched, V(out2) unmatched.
Old 8th June 2010, 09:15 AM   #2
R.I.P.
interesting.
I will be following you and the ensuing discussion.
regards Andrew T.
Old 9th June 2010, 04:20 AM   #3
panson_hk's Avatar
This simulation compares single-pair output to four-pair output. There are two cases for the four-pair output: all identical NPN and unmatched NPN as in the previous example.
Single-pair THD = 0.133%
Four-pair (matched) THD = 0.115%
Four-pair (unmatched) THD = 0.0264%
Does the result make sense?
Spice schematic is shown in the picture. FFT shows single-pair and unmatched four-pair output.
Old 9th June 2010, 10:34 AM   #4
panson_hk's Avatar
Base stopper resistors are added to the above circuit. One simulation is for all base resistors equal to 10 R. One simulation is for different stopper values for the four NPNs. All NPN/PNP are identical (perfectly matched).
single-pair, 10 R stopper: THD (4R) = 0.66 %, THD (8R) = 0.262 %
four-pair, 10 R stopper: THD (4R) = 0.236 %, THD (8R) = 0.131 %
four-pair, 10R, 15R, 20R, 12R stopper for NPNs: THD (4R) = 0.2033%, THD (8R) = 0.118 %
Different stopper value cause each NPN passing different bias current.
Is it a valid method to simulate unmatched pairs? Does the simulation make sense? Does matching not improve but degrade overall linearity?!!!
File Type: jpg output EF single vs multiple with stopper.JPG (156.3 KB, 245 views)
Old 9th June 2010, 11:07 AM   #5
R.I.P.
Yes, and different output current sharing.
The stopper subtracts Vrs from Vbe multiplier and the remainder is applied as output Vbe. a very small change in output Vbe will give rise to very different current sharing.
I match base stoppers and match emitter resistors as well as match output devices. Other wise there would be no point in doing any matching.
That's why I want to see discussion of your sim predictions.
regards Andrew T.
Old 9th June 2010, 12:01 PM   #6
panson_hk's Avatar
How tight you match the stopper and Re? Do you think a curve trace helpful in transistor matching?
Old 9th June 2010, 12:26 PM   #7
R.I.P.
base stopper, if fitted, and Re <=0.5%
I clamp the two outputs together with a strip of aluminium between.
join the bases and apply a Vbe until Ic matches the operational current. This only sets the Vbe to Ic match.
You also need an hFE match at operating Ic.
This time you add a pair of base stoppers and apply the V through them to turn on the output devices. Compare voltage across the base stoppers to find hFE matches.
You can do these tests in either order after rough sorting into similar parameter groups.
I tend to do the base stopper resistor measurements first. When I have pairs that look as likely matches I short out the stoppers and adjust the Ic back down to operating IC.
Using a 317 as CCS set to 2times operating current does this adjustment automatically.
The next stage would be to alter the 317 CCS current and see if your selected pair match over a range of operating currents. This would be equivalent to using a curve tracer. I do not do this Ic sweep with output devices. I reserve this level of matching to LTPs only.
regards Andrew T.
Old 9th June 2010, 03:09 PM   #8
panson_hk's Avatar
Thank you Andrew. Beside current sharing, have you seen any performance gain by matching these components?
Old 9th June 2010, 06:04 PM   #9
h_a is offline h_a  Europe
h_a's Avatar
Honestly, I think your findings do not make much sense. There is no distortion cancellation mechanism at work that somehow does not work for matched pairs. It's a pity I can't have a closer look at this right now to help you find the cause.
Matching in output pairs is only done to ensure all devices reliably turn on and as VBE variations are tiny compared to VGS of mosfets, it's commonly done only for mosfets.
For current sharing, the usual degeneration does the job.
All the best, Hannes
Old 9th June 2010, 10:34 PM   #10
nigelwright7557 is online now nigelwright7557  United Kingdom
nigelwright7557's Avatar
I suspect a lot of the nastys associated with unmatched transistors expected are got rid of by feedback and emitter/source resistors.
I have built numerous amps and never bothered matching MOSFET's and they have all worked and sounded fine.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Parallel output with/without matched devicesHide this!Advertise here!
Output Devices ! cloud Pass Labs 11 10th November 2008 11:37 PM
Output devices? Mr Evil Class D 42 12th January 2005 02:18 PM
Parallel Devices in Zen Variations Part 3 Cephas Pass Labs 4 10th May 2002 03:25 AM
Aleph 3 with 4 output devices yasalam Pass Labs 2 27th March 2002 03:34 AM
More Output devices...A75 FBJ Pass Labs 14 19th March 2002 06:18 AM
