German Translation Needed: Bias Setting for Denon PMA-520
Old 7th June 2010, 10:47 PM   #1
DreadPirate is offline DreadPirate  United States
DreadPirate's Avatar
Default German Translation Needed: Bias Setting for Denon PMA-520
This is the bias setting procedure on the PMA-520 (see link below). It's in German and I've been able to make out a good deal of it, but if someone could annotate my procedure below so that I don't miss the finer points, would be appreciated:
Initially set the following:
Power- OFF
Volume- Minimum
Loudspeakers- Discconnected (A and B)
All other settings at midpoint
1.- Don't understand this.
2 thru 4.- Turn Power ON. Measure at TP1/TP3 with voltmeter. At 10 seconds: .5mV +/-.2mV. At 5 minutes: 3mV +/-.5mV. At 15 minutes: 5mV +/-.5mV. Adjust VR403 (L) and VR404 (R) for these values.
5. Inject a 1KHz/100mV signal into the tuner input and turn Volume to maximum.
6. (For PMA-520) Measure at TP2/TP4 with voltmeter. Adjust VR405(L) and VR406(R) to 20mV +/-3mV.
The image does not read well on the screen, you will have to download and open in a viewer. Right click the image and use the "Save As" command to save it to your computer. Sorry.
Old 8th June 2010, 04:25 AM   #2
EUVL is offline EUVL  Europe
Babelfish will get you far enough.
Patrick
Old 8th June 2010, 05:01 AM   #3
Jan Dupont is offline Jan Dupont  Denmark
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
Turn Power ON. Wait 10 sec. Measure at TP1/TP3 with voltmeter. Adjust to .5mV +/-.2mV using VR403 and 404. Wait 5 minutes and adjust to 3mV +/-.5mV. Wait 15 minutes and adjust to 5mV +/-.5mV.
For 10 min. keep adjusting VR405 and 406 to keep 20mV +/-3mV.
Pretty basic bias adjustment
Free Schematic and Service Manual downloads www.audio-circuit.dk, Spare time company (just for fun): www.dupont-audio.com
Old 8th June 2010, 12:28 PM   #4
Thanks.
Old 10th June 2010, 12:50 PM   #5
EBM_dude is offline EBM_dude  Germany
EBM_dude's Avatar
BIAS CURRENT
-Setup
1. Install device in a normal position and protect from direct draft of A/C or fans.Carry out adjustment at a room temperature between 15°C and 30°C.
2. Set control elements to the following:
POWER BUTTON -> OFF or STANDBY
VOLUME CONTROL -> CCW [counter clockwise] until stop
SPEAKER TERMINALS -> open (connect neither speakers nor load resistors or similar)
-Adjustment:
1. Open top cover, then [put a] DC voltmeter on the measuring points of PCB number 1U-1608-1 (EQ.- and amplifier module).
2. Plug in power plug and switch power button to "ON". Within 10 seconds turn up VR403 (left channel) and VR404 (right channel) so much, that the voltmeter shows 0,5 mV +-0,2 mV.
3. Warm up for 5 minutes, then adjust VR403 and VR404 so thet the voltmeter shows 0,3 mV +- 0,5 mV.
4. After 15 minutes of warming up, adjust VR403 and VR404 so thet the voltmeter shows 0,5 mV +- 0,5 mV.
5. Apply a signal of 1 kHz and 1V RMS and turn up volume to maximum.
6. Now the voltmeter should show a slightly higher value (max. about 10 mV), now adjust the trimpots VR405 (left channel) and VR406 (right channel) so that the voltmeter shows 20 mV +-3 mV.
7. After another 2 minutes, adjust VR405 and VR406 to 35 mV +-3 mV (PMA-720) respectively 20 mV +-3 mV (PMA-520).
8. After 10 minutes of warm-up, adjust VR405 and VR406 to 40 mV +-3 mV (PMA-720) respectively 20 mV +-3 mV (PMA-520).
I hope I got it all right.
Old 13th June 2010, 12:57 AM   #6
The 100mv signal to set the bias, is that typically vpp or vrms? I'm using a meter without rms capability to measure the output of a cd player playing a 1kHz tone and using the volume control to vary the output. This is my signal generator. If vrms, then I need to read 282mv on my meter.
Old 13th June 2010, 01:03 PM   #7
I'll answer my own question here. The manual states "effective" voltage, which is another name for RMS.
Old 13th June 2010, 01:07 PM   #8
infinia is offline infinia  United States
infinia's Avatar
Originally Posted by DreadPirate View Post
Ich werde meine eigene Frage hier zu beantworten.
Old 13th June 2010, 05:34 PM   #9
Die llamas sind größer als die frösche.
Old 13th June 2010, 06:26 PM   #10
Ron E is offline Ron E  United States
Ron E's Avatar
Ha!
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. —Aldous Huxley
German Translation Needed: Bias Setting for Denon PMA-520Hide this!Advertise here!
Denon PMA-520 Integrated Amp "Buzz" DreadPirate Solid State 9 19th September 2017 05:07 PM
Adding Additional Outputs to An Existing Denon PMA-520 Integrated DreadPirate Solid State 3 8th June 2010 12:50 AM
Denon PMA-520 Blown Outputs Perhaps DreadPirate Solid State 1 3rd May 2010 09:30 PM
Need Denon PMA-750 Bias Procedure mvarney Solid State 1 1st March 2007 05:59 AM
german to english translation HELP! JC Fardo Everything Else 8 21st March 2005 09:46 PM
