Hi All,
I bought this old Pioneer a while ago to learn about fixing amps and practice soldering on. It had constant crackling and popping through both left/right channels and both A and B speaker outputs and one dead channel. Cleaning the balance pot sorted the dead channel simple enough. I replaced all of the easily identifiable caps bit by bit and the crackling got better and worse and went away and got worse and got better as i went...kept at it, running out of time/money and then coming back every couple of months.It is pretty good now but still crackles a bit mostly before it warms up. I really just want to get it finished. There are four pale blue caps, two of which buzz and crackle when touched and I suspect if I could replace them it would make all the difference but they don't have farad or volt ratings on the jackets. If there is anyone out there who has recapped one of these units or who recognises these caps I would be very grateful for your help. A schematic would be great, I can't read them but I plan to learn that too so what better time? These are the blue caps they are Sanyo and the jacket reads M509 on one side and 1/25 on the other IMG_2992.JPG Also these clear plastic caps with pink jacket that reads 6800J WV.50 IMG_2994.JPG I promised myself that I would not do anymore work on the aesthetics until I got the thing sounding better but for those who are interested I have sanded back and rusted up the cover and all the knobs were missing so I have corks on the front for now. I will eventually make some nice nobs out of a red wood and switches out of cow bone and stencil controls over the front. The corks look pretty daggy (that's Oztralian for not real good) so I won't post pics just yet... |
#2 |
Oh and thanks for your time...
#3 |
the blue one is an electrolytic and changing it will probably help ...that will be 1mf/25 volt .... then dont second think about it .... all electrolytics in old machines need to be replaced ...
the other capacitor is 6800pf and its a mica solid state part doesnt need to be replaced some more info can be found here vintage amplifier repair/upgrade manual regards sakis
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#4 |
5 minutes and problem solved...thanks Sakis
#5 |
Cap on second picture is polystyrene, not mica
#6 |
yeap ...you are correct .... i looked at the picture before having my first cofee ...
#7 |
I'd also recommend that you try and clean the dust off the board. Dust is hygroscopic (attracts water) and if you live an area with high humidity you may just find that suddenly on a "wet" day that all your replacing of those electrolytic caps and more have gone up in a flash due to a flash-over between two components.
Don't ask how I know about this. Computer PSU's are notorious for doing just that "poof" at switch-on and that stench... |
| Pioneer SA 9900 | David Robert | Solid State | 5 | 8th February 2007 04:27 PM |
| pioneer SA-1520 | murat | Solid State | 2 | 23rd February 2005 03:56 AM |
| Identifying caps, PIO? | adalin | Parts | 3 | 27th October 2004 04:03 PM |
| old Pioneer sa-5300 | Matt Neilson | Solid State | 10 | 8th April 2004 07:36 AM |
| Help Identifying Caps/Res ? | Lusso5 | Parts | 2 | 23rd September 2003 07:42 PM |
