I use this 565 for a DIY sub in my man cave, I did not use it for several weeks and now it won't power up. I get the line voltage going into the soft start board but no output(s).
#2 |
I did some basic checks last nite, the 4.7/20w resistor is open! Any sources for this and possible causes? Thx
#3 | |
The resistor is probably placed in series with the transformer. When you apply power, the resistor limits the inrush current. Moments later a relay should switch the resistor out of the circuit and connect the traffo directly to the mains. The instantaneous power the resistor is forced to allow through it will be many times the long term capability of the component. But because it only has to survive this for 0.5 a second or so, it's usually not a problem. Now either the resistor gave up the ghost or something else has gone wrong. Maybe the relay that switches the resistor out of the circuit has failed in some way. This would be potentially lethal to the resistor as now the entire current demands of the amp would be forced through it. 4.7R does seem a bit low of a value however, I would expect something a bit higher, what size is the transformer?. So perhaps the resistor isn't doing what I think it's doing. Nevertheless it might be worth figuring out exactly what the circuit is doing (It can't be that complicated) before moving forwards. If possible you want to make sure that this isn't going to happen again.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack! |
| Adcom GFA-565 Board | grateful_carl | Solid State | 17 | 25th July 2009 11:50 PM |
| Adcom GFA-565 Driver Board Cancer | Numbdiver | Solid State | 27 | 20th February 2009 03:06 AM |
| Adcom GFA-585 Blown 20w 4.7ohm on soft start board | ben62670 | Solid State | 133 | 31st January 2009 09:08 PM |
| Adcom GFA-565 Mono Board Leakage | grateful_carl | Solid State | 0 | 26th October 2007 07:50 AM |
| Commercial Soft Start board | wytco0 | Parts | 0 | 5th August 2005 04:26 PM |
| Page generated in 0.07450 seconds (72.21% PHP - 27.79% MySQL) with 10 queries |
