#21 | |
Banned
Thanks for that link. It ended up pointing to this schematic: http://www.soton.ac.uk/~apm3/diyaudi...no_circuit.jpg which looks promising. I'm still scratching my head over some of the aspects of the design of that amp. |
#22 |
>>>"What is the point in tying to cascode the VAS stage anyway?"
In Slone's case, it seems to me that it is necessary in order to implement his soft clip circuit. He biases the inner transistors with a voltage diovider that sets the bias at 1/2 the difference between the output signal boltage and the rails. You can see this in the "'OPTI-MOS" design posted on www.sealelectronics.com. You may also notice that in this design he, too, abondonds the current mirrors. I, too, tried modeling something like the original poster (used SIMetrix) and find it troublesome. My conclusion so far is that it doesn't provide enough current to the dominate pole capacitors at higher frequencies and reducing the resistor values beyond some point results in IS oscillations. Andy C may be on the right treack as it looks like something is needed to get greater current out of the IS. These are only my very amatuer guesses. It should be noted that a number of people here have built the OPT-MOS design without repoting any problems. I don't think the design *exactly* as posted was ever presented as a complete amp in any of Slones books so it may be going a bit far to dump on Slone for a design didn't propose. As a further note, the OPT-MOS design seems to be going into commercial production (ZUS Electronics) and Slone is wrapping up his on-line business. He says he may continue to sell the remaining OPTI-MOS pcbs but that's abot it. |
#23 | |
used buffering between input and VA stages in any of the designs, although he discusses the possibility. Well, I don't have time to see what he writes about it now, since I really ought to get my suitcases packed to go away for a week. I was just so puzzled since I didn't remeber him using this design, that I had to ask you right away. |
#24 | |
Account Disabled
#25 |
To Andy C, et al,
I just opened the Slone book to Fig 11.12, page 351. My vision may be clouded with age, but I think that the cicuit you presented to start this thread is similar but NOT exactly the same as Slone's. I suggest you run a simulation on the exact circuit first, then make one mod at a time. I have tried the same thing: take a piece from one example that I though looked good and tried to match it up with another piece withth idea of getting the best of everything; then I find they just don't work together! Very frustrating. Both Self's and Slone's books make it seem like designing a unique amp cicuit should be possible with a little cut and paste plus a SPICE simulator. In fact I'm comming to the realization that it's actually damn hard. I get the feeling that both of these guys have a lot of experience in their heads that doesn't come out in the books. Probably can't. It may be the only way to get from here to there is to be willing to try a lot of things and blow up a lot of transistors. (Done enough of that that my wife made me buy a CO2 fire extinguisher to keep by the bench.) |
#26 |
Account Disabled
two questions:
1) how do the the first 2n5551 and 5401 on the input stage got its bias? 2) what do those four bd139 do? |
#27 | |
Banned
#28 | |||
Banned
#29 |
" I believe I mentioned that I made some superficial modifications (in the current sources for the input diff amp for example) to avoid possible copyright issues."
As I said, I've been down the that road and discovered that what I thought were "superficial modifications" were not so superficial after all. At least in the sense that Slone's circuit worked and mine was crap. Part of my post was also prompted by another post that expressed some negative vibes about Slone publishing unworkable circuit's. While Slone can take care of himself, I wouldn't want a reader to avoid building one of Slone's amps just because of that one statement which was based on a mod of Slones circuit rather than the original. Not long ago I took one of Slones circuits and put in a SPICE model, then more or less systematically varied the component values. There seem to be two categories of values: those that make little if any difference over a broad range and those where the slightest change degrads the simulated performance. I suspect Slone spent a lot of time with a simulator to fine tune the final published circuit. |
#30 |
Andy,
Just some food for thought. I was a little unclear. I meant that each transistor in the signal path adds distortion. A CCS adds some distortion because its effective impedance is non-linear but the idea is that it is so much higher than a simple resistor that the net effect is to greatly reduce the non-linearity of the diff pair as you say. I'm not so sure the same can be said of a current mirror, where signals are amplified. Some care is needed as you know. A well designed diff amp has extremely low distortion when dynamic Ic changes are small and so the benefit of a current mirror in reducing common-mode error may be countered by the non-linearities of the current mirror itself. Another thought is about the output Z of the VAS. It appears to me that the transistor's impedance will be swamped by the miller cap feedback loop and, in addition, will be in parallel with the impedance of the output stage and loudspeaker. Worrying about the "Early effect" may be guilding the lilly as it were and may not be a good reason, on its own, for cascoding the VAS transistor and introducing another semiconductor into the signal path. |
| Project 11.1 from Slone "High-Power Amplifier" Book | Karl71 | Solid State | 46 | 6th October 2008 03:47 AM |
| Is Aleph 2 unstable < 6 Ohm??? | Thago | Pass Labs | 4 | 13th July 2007 10:29 PM |
| Are those worth buidling!!! -- > Randy Slone book.. | JinMTVT | Solid State | 0 | 12th July 2004 04:26 AM |
| Unstable when connecting PSU | Nysan | Solid State | 0 | 28th February 2004 04:10 PM |
| Page generated in 0.13703 seconds (82.82% PHP - 17.18% MySQL) with 11 queries |
