This red device (diode?) has a burnt area all around it. I assume the cap is bad along with a burnt resistor.
Is this a zenier diode? I do not have a schematic, however the back side of the board has the diode symbol and a long "Z" or "N" in front of it. I copied the markings off of the back of the board- they are on the pix, because they are hard to see through the burn marks. (see pix). If it is a diode, what size would I replace it with??? Any help would be appreciated. _john |
#3 |
I just paid $5.00 for a junk schematic! Problem still not solved. Thanks for the input Netlist.
#4 |
hello.
yes,looks like a (z)diode......... have you tried to measure it (with a dmm)? greets |
#5 |
It looks like it got quite hot. I don't know if it would work???
The amp doesn't work, so I'm assuming that it is the faulty part. I got a junk schematic, maybe I'll chance it and replace it w/ a zenier? |
#6 |
z diodes often run hot a little bit in operation.........
can you measure the voltage drop of this part? |
#7 |
Yup,
I get .665 one way and open the other way. Holy diodes batman! I guess that it is working. The resistor near it is shot and maybe the cap is bad, the cause of the strife. I'm a parts changer, not a wiz. -John |
#8 |
.........yes,looks like it is not burnt' through...........
btw cannot translate 'holy diodes batman' ? greets |
#9 |
#10 |
..........yes......sometimes we have here "holy arnold (schwarzenegger)" but doesn't help in electronics..............
good night.....1 am............. |
| Help me id this amp | MUSICNUTS | Solid State | 2 | 28th February 2010 12:50 AM |
| SMD diode ID please | Perry Babin | Parts | 5 | 8th October 2008 03:14 AM |
| diode bridge - 10000uF cap - diode tube - small cap - HV+ | engels | Tubes / Valves | 5 | 29th January 2008 10:16 PM |
| hybrid power supply: diode bridge into diode tube | engels | Tubes / Valves | 8 | 24th September 2007 09:18 AM |
| Please help ID this: | martioz | Everything Else | 0 | 27th June 2006 04:34 AM |
