I just got a Soundcraftsman MA 5002 Amp.
I am told it doesn't work. First I disconnected the bridge rectif, and checked for DC voltage. The transformer and rectifiers seem okay with +- 63vdc and +-40vdc. Next I did a visual inspection, there is a board near the transformer that is fed from the main fuse on the back and feeds the main transformer. There is a red resistor sized device that looks like it is burnt, the board is stained all around it front and back. Any help on IDing this board would be great and what to replace? see pix (burnt device middle right). What should I check next, before hooking the power back up to the mosfet boards? Also any good ideas on the best way to clean the dust and crud off of all of the remaining circuit boards? Thanks! John |
#2 |
I noticed that there is a fried resistor right near the "red" device that is also burnt.
I'm still not sure what the red device is? I can probably figure out the value of the resistor and replace the cap... |
| Burnt Tantalum Resistor Question | milezone | Solid State | 2 | 30th September 2009 10:27 PM |
| Need some advice rebuilding/upgrading 2 power amps. | SuperKris | Solid State | 31 | 26th May 2009 04:24 AM |
| Burnt & Destryed my virtual resistor! | lineup | Solid State | 1 | 20th January 2009 03:42 AM |
| Advice needed about Lexsen power - photo attached | Brit01 | Solid State | 2 | 28th July 2008 09:05 AM |
| Question on ID resistor | Thomas001 | Parts | 1 | 1st May 2004 12:32 AM |
| Page generated in 0.07961 seconds (62.34% PHP - 37.66% MySQL) with 11 queries |
