Creating center tap from two transformers - Page 2 - diyAudio
Old 30th May 2010, 10:11 PM   #11
EBM_dude's Avatar
Exactly. Thanks guys!
Old 30th May 2010, 11:00 PM   #12
The use of 2 is abundantly clear. The mass of 300 VA of E-I transformer may not be.
Ian
Old 1st June 2010, 10:23 PM   #13
EBM_dude's Avatar
I don't plan on carrying that amp around much. It will be set up on my desk and stay there until for example I move house.
Old 18th August 2011, 08:32 AM   #14
In order not to open another thread I wanted to ask a question on obtaining a ceter tap. I reently came across a stock of pcb transformers:
not very powerful but often handy for small DAC/electronic applications.
The xmfrs I have are 220v - 13 13 no center tap.
If I connect the inputs in parallel and the secondaries (careful to the phase) could I obtain a 13 -0 -13 transformer?
Thanks.
Old 18th August 2011, 09:52 AM   #15
You tell us it has a 220Vac primary.
To connect the inputs in parallel you need to start with a dual primary. What are you going to parallel?
The secondary is 13 13 no centre tap.
Do you mean 0-13Vac, 0-13Vac = dual secondary with 4 connecting pins?
I think I can read:
230V 5VA
0 15V 0 15V
printed on the top panel.
That is likely to to be a 230:15+15Vac transformer.
Measured open circuit will likely be 18+18Vac to 20+20Vac
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 18th August 2011, 10:05 AM   #16
I am sorry....the picture was just for reference should have cleared that in the post
The secondary is 13vac + 13vac
the primary is 220v
Is there any way I can obtaina center tap by using multiple transformers like the one described?
Old 18th August 2011, 10:14 AM   #17
east electronics's Avatar
it... is very possible .... what you actually have to look at if the primary is 220 or 230 ... this actually is not a minor diference
if trafos are 220 rated runing them in 230 and often at nights 240 might be an issue and trafos will not make it in long run terms
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 18th August 2011, 10:15 AM   #18
Actually 230v I just had in mind our own national grid lines...they tend to drop close to 220v.
the trafos are 230v input 13+13 secondary
Old 18th August 2011, 10:28 AM   #19
sofaspud's Avatar
My guess is the transformer in the picture has a 2-pin input and 4-pin outputs. Connecting the two middle pins of the output gives +0- at a good 100mA or so.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 18th August 2011, 12:47 PM   #20
Bigun is offline Bigun  Canada
Bigun's Avatar
why ?
p.s. using two trafo's is what I plan to do in a project. It's mainly to use up junk trafo's that I have. But it gives me the means to wire the primary for Canada or UK in the future. It also allows me to distribute the weight better inside the chasis.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
No center tap Help FastEddy Power Supplies 57 19th April 2010 07:01 PM
Center-tap to ground? cbutterworth Tubes / Valves 3 17th January 2007 09:18 PM
Gainclone and center tap marcus7601 Chip Amps 2 29th November 2006 02:12 PM
Transformer Center Tap dswiston Parts 2 4th February 2004 03:09 PM
Center tap question cmcgraw Solid State 1 26th December 2001 09:41 PM
Copyright 1999-2017 diyAudio
