Creating center tap from two transformers
Old 18th August 2011, 02:22 PM   #21
smartx21 is offline smartx21  Brazil
Send a message via MSN to smartx21 Creating center tap from two transformers
Let's clear things up.
If the outputs are 2-legged only, then you will need two transformers to attain a center tapped configuration.
No problem to parallel the inputs under 220 or 230V, since this is the way everything gets connected after inserting a plug to the mains in the wall.
Connecting outputs in series has been discussed earlier in this thread, so no need to tell the whole story once again.
All the way, feel free to post your doubts. Also actual pictures will help a lot!
Max.
Max.
Creating center tap from two transformersHide this!Advertise here!
No center tap Help FastEddy Power Supplies 57 19th April 2010 08:01 PM
Center-tap to ground? cbutterworth Tubes / Valves 3 17th January 2007 10:18 PM
Gainclone and center tap marcus7601 Chip Amps 2 29th November 2006 03:12 PM
Transformer Center Tap dswiston Parts 2 4th February 2004 04:09 PM
Center tap question cmcgraw Solid State 1 26th December 2001 10:41 PM
