500va transfomer 3 secondaries no centre tap - diyAudio
Old 27th May 2010, 04:45 AM   #1
Default 500va transfomer 3 secondaries no centre tap
I have a transformer with 3 secondaries 24vac 30vac and 34vac and i would like to use it for a 200 watt amplifier. I don't understand how to get a centre tap from this transformer or if i can parell the secondary's up to get it or what the best option is to use is it has a configuration like this
____ 0 volts
____ 24 vac
____ 30 vac
____ 34 vac
The transformer is 500va surely there must be a way i can hook this up and use it for my amplifier if anyone can help me with a schematic on how to do this it would be greatly appreciated.
Old 27th May 2010, 05:37 AM   #2
infinia is offline infinia  United States
infinia's Avatar
The way you describe the XFMR is that it has one secondary winding with 2 Taps. There is no tap at 1/2 so there is no way to get balanced or centered DC supplies. One way to maximize the transformer and power out is to develop a single DC voltage DC using the maximum 34VAC. Using a full bridge rectifier and single large cap to produce a single supply 0.95(34x1.4) - 2Vdiode or ~ 43 Vdc. so not nearly enough voltage to get 200 W into 4 ohms. There are capactor coupled output bridged amps to get the most out of this XFMR for audio giving close to 200W at 4 ohm.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 27th May 2010, 08:38 AM   #3
AJT is offline AJT  Philippines
AJT's Avatar
you can use a full wave voltage doubler on the 0-34vac to get, +/-43 volts....not enough to get you 200 watts .....
the best advertisement for a good audio design is the number of diy'ers wanting to build it after all the years....never the say so of so called gurus....
Old 27th May 2010, 09:48 AM   #4
bobodioulasso's Avatar
Voltage doublers are not suited to deliver current.
From a 47.6 v (= 34v x 1.4) single supply , it is possible to build an about 75 watts/8ohms bridged amplifier.
Paralleling two such amps would give 150 watts. Though this would need 4 identical modules per channel.
Old 27th May 2010, 09:51 AM   #5
AJT's Avatar
that is true...we are merely discussing possibilities here...
Old 27th May 2010, 10:12 AM   #6
There is one way: Google for Quad 606 or 909 schematic and look at PSU.
Old 27th May 2010, 01:49 PM   #7
wg_ski is offline wg_ski  United States
Next time, buy two.
Old 27th May 2010, 02:31 PM   #8
sregor is offline sregor  United States
2 full wave bridges, run of the the zero and 34 volt tap. One bridge for positive, one pridge for negative. Or 2 single diodes, one for plus and one for minus, and large filter cap (half-wave rectifier). Then bridge output. If stereo, pushes power limits on transformer - but would be OK for music. YMMV. My 2 cents.
Steve
Old 27th May 2010, 02:33 PM   #9
Originally Posted by sregor View Post
2 full wave bridges, run of the the zero and 34 volt tap. One bridge for positive, one bridge for negative.
no.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 27th May 2010, 09:47 PM   #10
nigelwright7557's Avatar
You could sell the transformer on ebay and buy a double secondary transformer.
Saves a lot of messing about.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk http://www.pcbcad51.co.uk
Heaters and centre tap duderduderini Tubes / Valves 10 17th November 2010 11:38 AM
How to connect two secondaries to get a central tap ginetto61 Power Supplies 3 12th May 2010 07:00 PM
no centre tap tranformer only 500va standard seedseed Power Supplies 6 11th May 2010 06:37 AM
centre tap or floating heaters? lt cdr data Tubes / Valves 3 23rd August 2006 07:35 AM
Center Tap vs Dual Secondaries StalfoS Chip Amps 6 18th March 2005 11:10 PM
Copyright 1999-2017 diyAudio
