Best replacement transistors for this amp?
Old 26th May 2010, 03:38 PM   #1
nitroboy is offline nitroboy  Slovenia
Default Best replacement transistors for this amp?
Hi
I hope this isn't a problem that I borrow your threat.
I was hoping that someone could tell me what would be the best transistor(mosfet) for my amplifier. It's an car amp and ia has 200W on 4 speakers. A friend gave it to me becouse he broke it. I've found the problem (a trasistor was blown). and i want to know what would be the best replacement or even better how much stronger could I make it.
thanks
Old 26th May 2010, 05:38 PM   #2
Jon Lord is offline Jon Lord  Germany
The transistors on your first picture are Bipolars (not MOSFETs) and they are fakes (no name, Chinese crap ... so this is the reason of failure).
You can't really use a different transistor than the current type, otherwise the bias current would be different and it doesn't seem to be adjustable.
One powerful alternative could be e.g. 2STA2120 and 2STC5948, but I doubt that replacing the bad transistors will really help, because certainly other devices are damaged.
My amplifier is very musical:
It accompanies myself on the grand piano, that's not half bad !
Old 26th May 2010, 05:42 PM   #3
I already know that ... I want to know what would be an replacement and if I could make it stronger...
and their all the same. Only two were replaced I think becouse there were marks on the pcb. but they their names scraped off.
sorry for my english...
Old 26th May 2010, 05:55 PM   #4
nitroboy:
I'm confused, are these 2SB and 2SD types the originals or not ? They aren't isn't it !!
Regarding the general question of this thread, did someone ever try the following MOSFET pair:
FQA36P15
FQA46N15 from Fairchild
These seem to be rather powerful and robust VMOS (planar stripe) type, which are damn cheap, low Crss and can dissipate at least 250W.
They already worked in a prototype of mine, but I never qualified them any further (measurement and listening wise).
Old 26th May 2010, 05:57 PM   #5
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
You cannot make it stronger because the extra heat is a problem and also the power supply is not big enough.
Try to find the correct parts or similar good quality ones.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 26th May 2010, 06:28 PM   #6
I have to replace them anyways so... but don't I have to worry that the pcb could be dameged when the transistor let's trough more amps ?
yes they are original the one on the photo isn't
Best replacement transistors for this amp?Hide this!Advertise here!
Replacement transistors/mosFETs for holton n-channel amp hulsebos Solid State 24 12th March 2010 04:56 AM
Transistors replacement funky2x Solid State 1 26th July 2008 12:20 AM
Replacement transistors vyju Parts 3 2nd February 2008 07:08 PM
Replacement transistors for leach amp Bosium Solid State 12 13th June 2003 09:07 AM
Replacement transistors for A968b & C2238B KenP Solid State 3 12th September 2002 08:11 PM
Copyright ©1999-2017 diyAudio
