QUASI Amplifier for Beginners
Old 16th August 2013, 02:08 PM   #791
masood is offline masood  India
Originally Posted by lyubcho88 View Post
Hi all,
Here is my version of QUASI amplifier with current protect and some changes of values.
schematic
url][https://www.dropbox.com/s/egkgh82fsasb8yi/schematic%20%2B-52V.PNG[/url]
Board
https://www.dropbox.com/s/jvfugcho97...i%20Layout.PNG
PCB for Print
https://www.dropbox.com/s/itv3qlde2y...per%20mini.pdf
And some of my projects with this circuit
https://www.dropbox.com/s/ugq9yguiqn...6012012616.jpg
QUASI Amplifier 2x180W
QUASI amplifier 2x180W | DIY Projects
Active Speakers with QUASI amp
??????? ?? ? LW1200 | DIY Projects
DIY SUB-woofer amplifier monoblock
| DIY Projects
QUASI Amp 2x180W peak power
QUASI amp 2x180W peak power | DIY Projects
BR,
Lyubo
dear sir
where is the board of your first schematic url][https://www.dropbox.com/s/egkgh82fsasb8yi/schematic%20%2B-52V.PNG[/url]
thanks
Old 16th August 2013, 02:50 PM   #792
lm324 is offline lm324  Brazil
[QUOTE=djk;3430864I used to buy the blank $6 Pass A40 boards (for the 40W class A design) and change every part on them to run at ±95V with six pair of MJ15024/24 for outputs and 2SA1302/2SC3281 for drivers. It would deliver between 600W/4Ω~800W/4Ω depending on the transformer VA.[/QUOTE]
Hi DJK,
Post schematic if possible.
Thanks.
Roger.
Old 17th August 2013, 01:44 AM   #793
djk is offline djk
R.I.P
djk's Avatar
"Post schematic if possible."
Same basic schematic, skip the FET, mount the bias transistor on the heatsink with the outputs.
Use high voltage parts everywhere.
You would need to make the board, it is no longer available for $6.
If doing a new board layout I would add anothe pad to the 2nd voltage amplifier and its current source, that way you could use the MJE340/350 pair, as well as the MPUS10/U60 that I used (unavailable), and the 2N3440/2N5415 (a common industrial part). 2N54xx/2N55xx parts for all the small plastic types.
Candidates for the Darwin Award should not read this author.
Old 18th August 2013, 08:24 PM   #794
Originally Posted by nazirdigi View Post
i asked this layout sir.
dear nazirdigi,
i want to make this pcb by toner tranfer method.can you send me that pcb image in reverse type thanking u.urs masood
Old 18th August 2013, 08:31 PM   #795
Originally Posted by apexaudio View Post
Quasi complementary amplifier based on old Dynacord. For begginers Class B without adjust.
dear apex,
plz send me pcb image by which i can make by toner tranfer method.thaniking u.
Old 27th August 2013, 04:38 PM   #796
dear apex,
in circuit input electrolytic cap is 2.2and 100micro farad respectively,but in component plan there is 1 micro and 47 micro farad what is right.regards
Old 27th August 2013, 10:12 PM   #797
mharko is offline mharko  Brazil
Hi Mr Mile
That model was based?
Thank you
Old 28th August 2013, 04:30 PM   #798
dear sir
transistor bc 546 is 80v trans.,bc547 is 60v trant. plz give me the equivalen of bc546 thanks
Old 12th September 2013, 03:15 PM   #799
lexy is offline lexy
DUS = 1N4148
Use this pcb as start point and AX11 schematic with MJ15003/15004 in output... and you will have nice smal PA amp with overcurrent protect (BC546, BC556, 1k, 470R...)
hello sir can you share the file of it to me here's my email add ...[EMAIL="a.buyo@yahoo.com.ph"/EMAIL]
thanks in advance
Old 11th May 2014, 10:38 AM   #800
Originally Posted by wattaniya View Post
RE-SIZED.
if anybody need PDF pls ask. I'll share.
both are mje350
QUASI Amplifier for BeginnersHide this!Advertise here!
How to identify a quasi-complementary amplifier? motbuddy Solid State 53 30th August 2017 08:05 PM
MOSFET/BJT QUASI AMPLIFIER WITH PROTECT!!! apexaudio Solid State 42 18th January 2015 09:22 AM
A.Holton AV400 using irfp or Quasi mosfet amplifier ? medogrizli Solid State 49 5th November 2011 11:04 PM
question about quasi nmos500 amplifier schematic? muky006 Pass Labs 3 8th May 2008 09:07 AM
Quasi N30 ClassA amplifier AndrewT Solid State 8 9th January 2008 07:57 PM
