QUASI Amplifier for Beginners
Old 31st January 2013, 09:31 AM   #741
vedmitraa is offline vedmitraa  India
vedmitraa's Avatar
Default Mr. Lelut, P.c.b. from your design
Mr. Lelut,P.C.B. from your design, where is the component list and circuit
Failure in Experiment is key to success .Only right combination is needed.
Old 31st January 2013, 03:10 PM   #742
lelut is offline lelut  Indonesia
Yes that the good question sir,
this layout create using sprint layout v5, first time i'm using this app,
i'dont know how to label components automatically,
i'm check manually back to schematic when put the components,
Old 1st February 2013, 11:59 AM   #743
PetruV is offline PetruV  Romania
How many pairs of 2n3055 will get me 400w or so since 2n3773 are expensive,or any other good transistors that will do this
Old 1st February 2013, 07:21 PM   #744
djk is offline djk
djk's Avatar
400W into what impedance?
The forward-biased voltage limit is only 60V, so you will need to build a bridge amplifier to get any real power.
Three pair per each half of the bridge on 30VDC should do what you want. You will want an output triple to bet enough current gain, use another pair of 3055s as drivers, and TIP41C/42 or similar for pre-drivers.
Candidates for the Darwin Award should not read this author.
Old 2nd February 2013, 09:28 AM   #745
250-500wats at 4 ohms,maybe 2 ohms but i only want to use only one speaker a big one
Old 2nd February 2013, 09:46 AM   #746
I think ll go with 2sc5200 maybe 3-4 pairs idk ,but i need a layout
Old 2nd February 2013, 06:19 PM   #747
Originally Posted by malik123 View Post
Here is pcb for BOS100 which is attached by Apex.
Which transistors can i use instead of BC639 and 2N3773
Tnx
Hi you can use 2n3055 as apex said but it wil yeld less powere and also you can use mje 340 350 from what i remember.
Have a nice day and a lot of luck building it
Old 2nd February 2013, 08:35 PM   #748
any cheaper 2n3773 alternative
Old 7th February 2013, 08:47 AM   #749
After more research i have foundthe 2n3773 cheaper'But not cheap enough and the 2sc5200 is cheaper and i heard its better soundinf so im going to use that
But i need pcb
Old 7th February 2013, 09:50 AM   #750
vedmitraa's Avatar
Mr. Lelut still waiting for schemetic and component values of your p.c.b. design
QUASI Amplifier for BeginnersHide this!Advertise here!
How to identify a quasi-complementary amplifier? motbuddy Solid State 53 30th August 2017 08:05 PM
MOSFET/BJT QUASI AMPLIFIER WITH PROTECT!!! apexaudio Solid State 42 18th January 2015 09:22 AM
A.Holton AV400 using irfp or Quasi mosfet amplifier ? medogrizli Solid State 49 5th November 2011 11:04 PM
question about quasi nmos500 amplifier schematic? muky006 Pass Labs 3 8th May 2008 09:07 AM
Quasi N30 ClassA amplifier AndrewT Solid State 8 9th January 2008 07:57 PM
