Old 4th September 2012, 07:06 AM   #721
olafk is online now olafk  Germany
Originally Posted by joeyt View Post
what is the power output of this compact module using -40v 0v +40v?
Please read the posts from #708.
regards, Olaf
Old 4th September 2012, 12:23 PM   #722
joeyt is offline joeyt  Philippines
no answer from post no.708. i read in this forum that the power output of a PA comes from the supply voltage with adequate heat sink to its output transistor. -40v 0v +40v maybe i will get around 90 watts in 8 ohms. correct me pls.if i am wrong
thanks,joeyt
Old 4th September 2012, 01:05 PM   #723
Default Andrew T. wrote in Post 700...
"+-30Vdc will sag to maybe around +-27Vdc when driving full power to a test resistor.
The voltage lost through the amplifier could be very approximately 3Vdrop when delivery that full power to the test load.
That leaves your maximum output voltage @ ~24Vpk.
Pmax = Vpk^2 / Rload / 2.
I predict your maximum power for a +-30Vdc supply as ~ 36W into 8r0"
I can not measure the output power of this module. But I hope the calculation from Andrew can give you a example.
regards
Old 4th September 2012, 03:31 PM   #724
AndrewT is online now AndrewT  Scotland
Joey,
why do you expect others to do your homework?
Read Olaf and read his reference post.
Old 2nd December 2012, 03:07 PM   #725
hello sir can any share amplifier bridging circuit
Old 15th December 2012, 06:43 PM   #726
Originally Posted by apexaudio View Post
I find paper with circuit of this amplifier with single pair 2N3773 and added VI limiter.
sir plz share pcb layout for this single pair amp
Old 14th January 2013, 05:56 AM   #727
lelut is offline lelut  Indonesia
Originally Posted by olafk View Post
I built the amplifier (picture see post #663) with two pairs of 2N3773 and I use +-60V DC. Now the Transistors MJE350/340 become to hot. I can touch them for only 3-4 seconds and I think it is a bit critical.
Should I reduce the voltage (have regulated power supply) or are there any other things I can do? I changed the heatsink to a bigger version for TO220 like the MJE15030, but gave no better result.
Can anybody help me?
regards
Olaf
Dear Sir Olaf,
How difference using +-60V or only using +-42V at sound (using 2N3773 final TR)?
more deep or more mid character?
And for your second kit, using 2n2922, how about sound character?
i will plan this schematic for outdoor PA using 8x2N3773 or 8x2N2922 per-channel.
thanks,
BR,
Made Sumber
Old 14th January 2013, 03:02 PM   #728
Hi lelut,
I have not compared the sound with different voltages. But I think, there's not much difference.
For my taste the 2N2922 sound a little better and more balanced in the bass - but that is very subjective.
I built the amps for my sons to make noise ;-).
For hifi I use ax14. Next project is ax20 with 3 pairs.
Sorry for the only few informations.
regards Olaf
Old 14th January 2013, 03:15 PM   #729
Vostro is offline Vostro  Madagascar
Vostro's Avatar
Olafk if you build ax20, please comment on how it compares to ax14 in apex100w thread,
Im interested to know how they compare.
Old 14th January 2013, 04:37 PM   #730
I will do so.
Regards Olaf
MOSFET/BJT QUASI AMPLIFIER WITH PROTECT!!! apexaudio Solid State 40 21st November 2012 01:37 PM
A.Holton AV400 using irfp or Quasi mosfet amplifier ? medogrizli Solid State 49 5th November 2011 11:04 PM
How to identify a quasi-complementary amplifier? motbuddy Solid State 8 24th April 2011 11:59 AM
question about quasi nmos500 amplifier schematic? muky006 Pass Labs 3 8th May 2008 09:07 AM
Quasi N30 ClassA amplifier AndrewT Solid State 8 9th January 2008 07:57 PM
Copyright ©1999-2013 diyAudio
